2014-04-23, 07:56
Which key/mouse is it? I have a few I can test.
(2014-04-23, 11:24)Chrisiooo Wrote: But in my case, the frameskipping problem, that occurs since around the last 4 Testbuilds, isn´t fixed. Nearly every Movie I have is skipping every 15-20 sec.
(2014-04-23, 12:05)popcornmix Wrote:(2014-04-23, 11:24)Chrisiooo Wrote: But in my case, the frameskipping problem, that occurs since around the last 4 Testbuilds, isn´t fixed. Nearly every Movie I have is skipping every 15-20 sec.
I don't know about the frameskipping problem. Has this been reported before?
You'll have to describe exactly what you are seeing, and what the last build is that doesn't have this problem.
(2014-04-23, 11:24)Chrisiooo Wrote: Its difficult to describe. Most of my videofiles I play are stuttering for less then a second every 10-20 seconds. I stream all from my harddrive attached to my airport extreme connected over ethernet to the raspberry. The network should'nt be the problem.No stutter at all here, both 1080p and 3D runs silky smooth. It sounds like when you are playing a PAL movie on a NTSC only system or visa versa. Or a network problem. Do you have "display refresh rate to match to video" set to on, and does your TV switch to the correct mode?
(2014-04-23, 16:08)tuxen Wrote:(2014-04-23, 11:24)Chrisiooo Wrote: Its difficult to describe. Most of my videofiles I play are stuttering for less then a second every 10-20 seconds. I stream all from my harddrive attached to my airport extreme connected over ethernet to the raspberry. The network should'nt be the problem.No stutter at all here, both 1080p and 3D runs silky smooth. It sounds like when you are playing a PAL movie on a NTSC only system or visa versa. Or a network problem. Do you have "display refresh rate to match to video" set to on, and does your TV switch to the correct mode?
I'm more prone to think that its the network though have you tried playing them back directly from a HD or USB stick?
(2014-04-22, 22:37)ismadder Wrote:(2014-04-22, 19:57)tomer953 Wrote:(2014-04-22, 15:49)ismadder Wrote: I had problem with no signal on my sony tv, the way i resolved it was to my sure Playback, is set to display 4:3 Normal, hope that helps
you mean to the "show 4:3 videos as.." - "normal"\"zoom"\"16:9" ........ this ?
cause in all my xbmc I always set this to '16:9" for old movies shows as a little square in the middle of the screen...
but I it will stop causing the problem, I will try it as soon I will be at home.
Yes that what i mean !!! i found that on my lg it worked ok but my sony bravia did not like it being set at 16:9, so i had set it to 4:3 normal
(2014-04-23, 07:56)tuxen Wrote: Which key/mouse is it? I have a few I can test.Logitech m315 nano-receiver (non-unifying)
usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52f
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.2: Product: USB Receiver
usb 1-1.2: Manufacturer: Logitech
(2014-04-23, 15:58)tuxen Wrote:Sure. How do I do this?(2014-04-23, 10:33)f1vefour Wrote: Sounds like the mouse may be generating too many interrupts.@edwr: Try measuring them so we can compare.
