  • 133
  • 134
  • 135(current)
  • 136
  • 137
  • 156
OpenELEC Testbuilds for RaspberryPi Part 3 (Kodi 14.0)
(2014-11-13, 15:44)popcornmix Wrote:
(2014-11-13, 13:58)sdsnyr94 Wrote: I'll test tonight to see if this helps my issue... does this affect dvdplayer only (leave omxplayer off)?
This is common code, so will affect omxplayer and dvdplayer.
I was only able to do a quick test, but after about 10 minutes the Audio/Video were still in sync (normally it would be out of sync within a minute or 2). I'll have a chance to test more Saturday, when I have time to watch a full game.
(2014-11-14, 00:17)Milhouse Wrote: Removed "CONFIG_REGULATOR=y" from linux.arm.conf to see if this helps fix Hifiberry hardware (please test, Hifiberry users)
YAY! My Digi works perfectly again Smile
Yes, also for me having a Digi on Raspi B build #1113 is running perfectly! Thank you very very much for the fix!
regards
What does your hifiberry.conf look like?
(2014-11-14, 22:59)ijsbeer79 Wrote: What does your hifiberry.conf look like?
like before with the modules
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_wm8804
snd_soc_hifiberry_digi
New OpenELEC Helix build: #1114
(Supercedes previous build)
# uname -a
Linux rpi512 3.17.2 #1 PREEMPT Fri Nov 14 21:11:27 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov  7 2014 17:01:00
Copyright (c) 2012 Broadcom
version 3bd41a132583ec90e4a0410a4aa631d1e4e2d8ea (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141114211018-r19633-g917fa5f [Build #1114]
Based on tip of OpenELEC master (917fa5f4, changelog) and tip of XBMC master (19893f87, changelog) with the following modifications:
  • Includes newclock4 patches
  • Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
  • Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Adapted service.openelec.settings to take advantage of PR:5217 [patch details]
  • Includes latest libnfs master (4a58e614)
  • Includes latest libcec master (70e1b5de)
  • Includes latest xbmc-pvr-addons master (06842b90)
  • Includes latest xbmc-addon-xvdr master (328fa653)
  • Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
  • Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes (see patch)
  • Includes commits from libcec-2.2.0 (popcornmix)
  • Includes PR:5573: webserver: improved caching control (see discussion)
  • Includes PR:5700: [WIP] Fix for libdvdcss partial read
  • Includes PR:5707: Even better emulate POSIX file functions (reduced)
  • Includes PR:5713: Fix "Current fanart" not being shown in DialogVideoInfo.
Build Highlights:
  1. HifiBerry confirmed working, CONFIG_REGULATOR dropped upstream
  2. [omxcodec] Don't force software codec with dvds
Build Details:
  1. OpenELEC:
    • v4l-utils: fix rc6_mce mapfile (67d30ac1)
    • dbus: update to dbus-1.8.10 (501619f3)
    • linux: add upstream patch (230295be)
    • projects/*/linux: disable CONFIG_REGULATOR, this fixes #3617 (917fa5f4)
  2. XBMC:
    • [pvr] bump addons (PR:5715, 1 commit, 2 files changed)
    • Coverity: Fixes 2 (PR:5711, 5 commits, 10 files changed)
    • [epg] rename GetCurrentTime() to avoid naming collision with Windows-specific macro (PR:5726, 1 commit, 2 files changed)
    • [cosmetics] minor spacing in readme (PR:5724, 1 commit, 1 file changed)
    • AE: always request float from sink when in fixed mode, fixes unwanted re... (PR:5718, 1 commit, 1 file changed)
    • [darwin] - fix flicker in sysinfo - querying gateway via pipe needs a sleep (PR:5728, 1 commit, 1 file changed)
  3. newclock4:
    • New commits in this build:
      • [omxcodec] Don't force software codec with dvds (c60186bb)
      • [dvdplayervideo] Make variables more local (ad2e59e9)
      • [dvdplayervideo] Move packet handling into separate function (72743cb3)
      • [dvdplayervideo] Prod decoder when in stills mode (fceab269)
    • Commits no longer in build:
      • [omxcodec] Fix for stills with hardware codec (072bc273)
      • AE: always request float from sink when in fixed mode, fixes unwanted re-init of sink (a5216bb3)
  4. kernel 3.17.y:
      • config: Remove CONFIG_REGULATOR - we don't have a regulator driver (8605f6d9)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
@popcornmix i have great news, since new version, my Special DVD Crashed and restart Kodi. In older version, it's hang and now, the DVD reboot Kodi.
here is the Log.
http://pastebin.com/QT4MjG6u
and other DVD's chrashed also with the menu
http://pastebin.com/QsG7wQ0k
http://pastebin.com/mqdT7iwg
(2014-11-15, 07:03)Mister XY Wrote: @popcornmix i have great news, since new version, my Special DVD Crashed and restart Kodi. In older version, it's hang and now, the DVD reboot Kodi.
here is the Log.
A restart suggests a segfault which often leaves very little information in the debug log.
What's normally required is a backtrace which you should be able to obtain by following the instructions in item #3 in the first post of this thread (just don't use a debug build, use your current non-debug build and ignore the 300MB requirement - the backtrace will be incomplete, but still better than nothing).
Or upload a sample file.
Edit: I can reproduce a crash with my test DVD ISO over SMB or NFS - it happens when I navigate within the menu (select a menu item => crash).
gdb (non-debug) backtrace from #1114:
Reading symbols from /usr/lib/kodi/kodi.bin...(no debugging symbols found)...done.
Starting program: /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
Cannot access memory at address 0x0
warning: Unable to find libthread_db matching inferior's thread library, thread debugging will not be available.
[New LWP 23681]
[New LWP 23718]
[New LWP 23706]
[New LWP 23712]
[New LWP 23715]
[New LWP 23709]
[New LWP 23729]
hwclock: can't open '/dev/misc/rtc': No such file or directory
[New LWP 23756]
[New LWP 23762]
[New LWP 23764]
Program received signal SIGSEGV, Segmentation fault.
[Switching to LWP 23764]
0x00834cec in CDVDPlayerVideo::HandleDemuxerPacket(DemuxPacket*, bool, int&, double&, CDVDMsg*, DVDVideoPicture&) ()
(gdb) bt
#0  0x00834cec in CDVDPlayerVideo::HandleDemuxerPacket(DemuxPacket*, bool, int&, double&, CDVDMsg*, DVDVideoPicture&) ()
#1  0x00000000 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Build #1113 does not crash and navigates the menu without a problem. Cannot reproduce the above crash in Kodi master on Ubuntu, so looks Pi specific.
@popcornmix if you need the backtrace from a debug build, let me know...
I have the same error
[New LWP 544]
[New LWP 578]
[New LWP 575]
[New LWP 569]
[New LWP 566]
[New LWP 572]
[LWP 569 exited]
[New LWP 587]
[New LWP 588]
[New LWP 619]
[LWP 588 exited]
[New LWP 622]
[Switching to LWP 622]
(gdb) bt
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_wm8804
I can't speak for the digi but with the DAC+ I only needed to load "snd_soc_hifiberry_dacplus" in hifiberry.conf. bcm2708_dmaengine doesn't exist any more and generates an error on boot if you try to load it.
(2014-11-15, 07:14)Milhouse Wrote: Edit: I can reproduce a crash with my test DVD ISO over SMB or NFS - it happens when I navigate within the menu (select a menu item => crash).
Yes, I could reproduce this. I've pushed a fix.
(2014-11-15, 12:41)kieranc Wrote: I can't speak for the digi but with the DAC+ I only needed to load "snd_soc_hifiberry_dacplus" in hifiberry.conf. bcm2708_dmaengine doesn't exist any more and generates an error on boot if you try to load it.
I can confirm this for the Digi, thank you!
One issue I've got with the latest builds #1113 and #1114 is that I cannot mount samba shares to /storage/folder anymore. I'm using the "old method" with autostart.sh containing commands like:
#!/bin/sh
(sleep 30; \
mkdir /storage/folder; \
mount -t cifs -o username=username,password=password,rw //192.168.1.254/folder /storage/folder; \
Are there any logs where potentially failed mounts are logged?
Thanks,
thent
Just try mounting your cifs share at the command line, what error do you see?
New OpenELEC Helix build: #1115
# uname -a
Linux rpi512 3.17.3 #1 PREEMPT Sat Nov 15 22:28:34 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov  7 2014 17:01:00
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141115222725-r19639-g80e4028 [Build #1115]
Based on tip of OpenELEC master (80e4028d, changelog) and tip of XBMC master (b3c20a2a, changelog) with the following modifications:
  • Included PR:3623: Tweaks for setting make's -j option
Build Highlights:
  1. New firmware.
  2. New 3.17.3 kernel.
  3. Fix for DVD menu crash (tested, works here - many thanks!)
Build Details:
  1. Firmware (Nov 7):
    • firmware: audio_mixer: Fix typo that stops OMX_IndexParamBrcmTimeScale from working
    • firmware: hdmi: Show more precision of hdmi pll setting
  2. OpenELEC:
    • hdhomerun: allow running scripts from addon settings (PR:3622, 1 commit, 6 files changed)
    • sundtek-mediatv: allow running scripts from addon settings (PR:3621, 1 commit, 11 files changed)
    • linux: update to linux-3.17.3 (9365f7e3)
    • ffmpeg: cosmetics (e275c974)
  3. XBMC:
    • AESinkPULSE: Rebrand pulseaudio sink name to reflect kodi (PR:5719, 1 commit, 1 file changed)
    • [buttontranslator] fix keymap overrides not working (PR:5712, 2 commits, 1 file changed)
    • dvdplayer: vaapi, vdpau - implement codec control flags (PR:5710, 1 commit, 2 files changed)
    • dvdplayer: fix dts correction, again (PR:5709, 1 commit, 2 files changed)
    • dvdplayer: avoid short screen flicker caused by unnecessary reconfigure ... (PR:5696, 1 commit, 1 file changed)
    • [rbp] Enable optimization on Raspberry Pi (PR:5677, 1 commit, 1 file changed)
    • [rtmp] fix crash on seek on live streams (PR:5693, 1 commit, 2 files changed)
    • Ukr and Rus language fixes (PR:5683, 1 commit, 3 files changed)
    • [mmalrenderer] Add choice of 3 deinterlace schemes (PR:5626, 1 commit, 9 files changed)
    • [keymap] Fix PS3 dualshock for SDL2 (PR:5637, 1 commit, 1 file changed)
    • videorefclock: use videosync DRM on AMD systems (PR:5716, 1 commit, 1 file changed)
    • dvdplayer: fix rewind (PR:5714, 2 commits, 5 files changed)
    • Fix suspend with upowerd >= 0.99.1 (PR:5651, 1 commit, 1 file changed)
    • [ResamplePi] Add support for formats that need shifting (PR:5731, 1 commit, 2 files changed)
    • [pvr] add missing call to parent's OnPrepareFileItems() (PR:5730, 1 commit, 1 file changed)
    • [lang] fix invalid or wrong language names to be in sync with Transifex (0ccc7e7f)
  4. newclock4:
      • squash: stills: avoid deferencing null packet (bc2e08ea)
      • [dvdplayer] Add lock for player creation (eb77209e)
      • [omxplayer] Fix for out of sync after trickplay (b40f2d0a)
      • hack: revert squash: don't update originaldts when marked as invalid (a6f0ed54)
      • [mmalrenderer] Add choice of 4 deinterlace schemes (b7f3eec8)
      • Revert "hack: revert squash: don't update originaldts when marked as invalid" (65effc02)
      • [DVDMessageQueue] Remove pi specific logging ifdef (ea28b1a2)
      • [ResamplePi] Add support for formats that need shifting (c6e842bc)
      • add canseek and drop unused rtmp options (e26404c3)
      • dvdplayer: avoid short screen flicker caused by unnecessary reconfigure of renderer (4e8aa1bc)
      • dvdplayer: allow rewinding at end of stream, do a seek after rewind (47cba84d)
      • dvdplayer: fix dts correction, again (ba4088a6)
      • player: fix rewind (a8d33f28)
  5. kernel 3.17.y:
      • snd-bcm2708: Fix dmesg spam for non-error case (588b0839)
      • config: remove CONFIG_DEBUG_INFO (1f6cd09d)
  6. Additional commits/pull requests not yet merged upstream:
Chapter skip on MP4s, which was just fixed a few days ago, does not always work on these builds. Some movies skip correctly to the next chapter marker, but others timeskip instead (showing +3:00 in the top right corner). This issue does not affect openelec 5.0 beta 2 on a pi, or helix beta 2 on a mac.
This is the mediainfo for a file that skips correctly.
This is the mediainfo for a file that timeskips instead.
  • 133
  • 134
  • 135(current)
  • 136
  • 137
  • 156
OpenELEC Testbuilds for RaspberryPi Part 3 (Kodi 14.0)8
