  • 138
  • 139
  • 140(current)
  • 141
  • 142
  • 156
OpenELEC Testbuilds for RaspberryPi Part 3 (Kodi 14.0)
New OpenELEC Helix build: #1124
(Supercedes previous build)
# uname -a
Linux rpi512 3.17.4 #1 PREEMPT Mon Nov 24 22:37:11 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov 23 2014 18:25:43
Copyright (c) 2012 Broadcom
version f3c57bbd789c59412f26651ea817b60197f3fdeb (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141124223600-r19690-gec9fd72 [Build #1124]
Based on tip of OpenELEC master (ec9fd727, changelog) and tip of XBMC master (968c6247, changelog) with the following modifications:
  • Includes newclock4 patches
  • Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
  • Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Adapted service.openelec.settings to take advantage of PR:5217 [patch details]
  • Includes latest libnfs master (4a58e614)
  • Includes latest libcec master (9f000e43)
  • Includes latest xbmc-pvr-addons master (06842b90)
  • Includes latest xbmc-addon-xvdr master (328fa653)
  • Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
  • Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes (see patch)
  • Includes commits from libcec-2.2.0 (popcornmix)
  • Includes PR:387: [pvr.mythtv] Release v1.9.26 (Helix) (kodi.pvr.addons)
  • Includes PR:388: [filmon] Fix harmless -Wformat-security warning (kodi.pvr.addons)
  • Includes PR:5573: webserver: improved caching control (see discussion)
  • Includes PR:5747: [database] - add setting for hiding watched movies/episodes in recently added lists
  • Includes PR:5752: [jsonrpc] Allow retrieving empty TV shows via VideoLibrary.GetTVShows.
  • Reverted PR:5764: jobs: fixed segmentation fault when thumbnail loader abort (Reason: Causes GUI to freeze)
Build Highlights:
  1. Kodi 14.0 beta4 with new logo
  2. Reverted: PR:5764: jobs: fixed segmentation fault when thumbnail loader abort (Reason: Causes GUI to freeze)
Build Details:
  1. OpenELEC:
    • projects/imx6/linux: build SPDIF driver as modules (db32b74a)
    • added package brcmfmac_sdio-firmware linux: added needed drivers for bcm43xx bluetooth devices (b1c4867d)
    • OpenELEC-settings: update to OpenELEC-settings-0.5.5 (488d2439)
  2. XBMC:
    • dvdplayer: update dropping stats after every call to decode (PR:5776, 1 commit, 2 files changed)
    • IMX6: Use correct Method for deletion (PR:5794, 2 commits, 1 file changed)
    • [rebrand] droid: splash layout and color (PR:5793, 2 commits, 2 files changed)
    • [Rebrand] replace all XBMC artwork with new logo (PR:5796, 16 commits, 101 files changed)
    • [release] bump to 14.0 beta4 (PR:5788, 1 commit, 2 files changed)
    • infomanager: fix calls to GetInt() without a valid file item (same as in GetBool()) (PR:5792, 1 commit, 1 file changed)
    • [cec] Fixed PeripheralCecAdapter application exit code handling. (PR:5786, 1 commit, 4 files changed)
    • [skin] update re-touched with new Kodi logo (5ec89990)
    • [addons] sync with repo (ae21c3dc)
    • [gitignore] - add VolumeIcon.icns to gitignore (828181a4)
    • [osx/packaging] - ensure that our dmg is always mounted with a static name (/Volumes/Kodi in our case) - else the prepared .DS_Store won't work and we don't get the background image and icon position (fb7649a5)
    • [osx/packaging] - premade .DS_Store which works for /Volumes/Kodi (968c6247)
  3. libcec:
    • Revert cec_set_configuration() to take non-const parameter to keep old ABI (PR:45, 1 commit, 1 file changed)
  4. newclock4:
    • New commits in this build:
      • [MMALCoded] Call port settings changed from callback to avoid thread unsafe code (beb2f253)
      • [mmalcodec] Skip deinterlace for dvd menus for now (b20f9f6c)
    • Commits no longer in build:
      • [dvdplayervideo] Make variables more local (2051b60a)
      • [dvdplayervideo] Move packet handling into separate function (6e8c273a)
      • squash: stills: avoid deferencing null packet (a835e82a)
      • Fixed PeripheralCecAdapter application exit code handling. (ba8a6043)
  5. Additional commits/pull requests not yet merged upstream:
    • Reverted: PR:5764: jobs: fixed segmentation fault when thumbnail loader abort (Reason: Causes GUI to freeze)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2014-11-25, 01:07)Milhouse Wrote: New OpenELEC Helix build: #1124
@Mister XY
Can you test this with your DVD menus? It has some fixes that may help.
Milhouse,
Quote:404 - File or directory not found.
And it's right, file doesn't exist... Rofl
(2014-11-25, 01:29)h.udo Wrote: Milhouse,
Oops, thanks - uploaded it again, should be there now.
@popcornmix, i have tested and it's run. Thanks for your help.
Has anyone else noticed any issues with UPnP in the last 10 or so builds?
I have a SMB share to the Pi which in turn the Pi shares over UPnP, it has never been an issue until lately. As I type this I realize the issue must be coming from the SMB share because it happens on the Raspberry and over the Pi's UPnP as well. I will reboot the SMB machine and go from there, so nevermind.
*edit*
The HD is going bad in the NAS, sorry for wasting forum space.
New OpenELEC Helix build: #1125
# uname -a
Linux rpi512 3.17.4 #1 PREEMPT Tue Nov 25 21:04:11 GMT 2014 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141125210258-r19690-gec9fd72 [Build #1125]
Based on tip of OpenELEC master (ec9fd727, changelog) and tip of XBMC master (4465fbfa, changelog) with the following modifications:
  • Includes latest libnfs master (080d2311)
Build Highlights:
  1. Kodi 14.0 beta5
  2. libnfs 1.9.6
  3. Upstream revert of PR:5764, for causing GUI to lockup
  4. Fix for ISO reads causing crash
Build Details:
  1. XBMC:
    • FIX: [aml] no video on newer aml sdk (PR:5803, 1 commit, 1 file changed)
    • Revert "jobs: fixed segmentation fault when thumbnail loader abort" (PR:5810, 1 commit, 2 files changed)
    • [libdvdread] - fix out of bound access when playing some iso files (PR:5806, 1 commit, 2 files changed)
    • [release] bump to 14.0 beta5 (PR:5811, 1 commit, 2 files changed)
  2. libnfs:
  3. newclock4:
      • [mmalcodec] Avoid double framerate deinterlace for dvd menus for now (7ffc7e16)
      • changed: Modify rate calculation to obtain a proper average with heavy seeking/cache swapping (4076f6c2)
      • changed: Don't perform wait-on-data if position is in our old cache (35bea50d)
      • fixed: it's stereo samples.. (69f17df3)
(2014-11-26, 03:07)Milhouse Wrote: New OpenELEC Helix build: #1125
Any testing of "double cache" streams would be useful. There's been a recent "double cache" fix merged, and another (https://github.com/xbmc/xbmc/pull/5808) is in this build.
I believe "double cache" is used when streaming from internet sites when the filetype is mp4, mkv, avi (i.e. most video types).
I think the bugs are related to stuttering near end of file, or behaviour after a seek.
Any improvements, regressions, or just "still working" comments would be useful.
Not sure if this a bug or a limitation of the Rpi. When viewing Live TV, If I leave it playing and decide to go and have a look at my tv shows or moves, I start to get a beeping noise and images appear as black boxes and eventually crashing, But i return back to live TV it doesnt crash.
New OpenELEC Helix build: #1126
# uname -a
Linux rpi512 3.17.4 #1 PREEMPT Wed Nov 26 21:35:50 GMT 2014 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141126213415-r19699-ge36e01e [Build #1126]
Based on tip of OpenELEC master (e36e01e6, changelog) and tip of XBMC master (488627a3, changelog) with the following modifications:
  • Includes latest xbmc-pvr-addons master (14d98287)
Build Highlights:
  1. SMB fixes
  2. Disable support for READ_TRUNCATED
  3. kodi-pvr-addons updates
  4. newclock4 dvdplayer: demux ffmpeg - fix seeking behind eof
Build Details:
  1. OpenELEC:
    • kodi: add PR5805 (e358d007)
    • libpng: update to libpng-1.6.15 (74d1c263)
    • xf86-input-evdev: update to xf86-input-evdev-2.9.1 (56afe53b)
  2. XBMC:
    • Revert "smb: eliminate unused while loop in OpenDir" (PR:5820, 1 commit, 1 file changed)
    • [win32] [vfs] Win32SMBFile::Stat(): fix wrong error code check (PR:5821, 1 commit, 1 file changed)
    • [libdvdread] - fix partial read in file_read (PR:5815, 2 commits, 2 files changed)
    • VAAPI: Print driver vendor string (which includes version) when opening context (PR:5822, 1 commit, 1 file changed)
    • [emufnc] Disable support for READ_TRUNCATED. To be reverted after Helix release (PR:5819, 1 commit, 1 file changed)
  3. kodi-pvr-addons:
    • [pvr.mythtv] Bump version 1.9.26 (PR:387, 1 commit, 1 file changed)
    • Rebrand (PR:389, 2 commits, 49 files changed)
    • [filmon] Fix harmless -Wformat-security warning (20fb124b)
    • Merge branch 'fix/format-string' of https://github.com/anssih/xbmc-pvr-addons into anssih-fix/format-string (1aeca007)
    • [pvr.filmon] bump version to 0.4.3 (229988b3)
    • Merge branch 'anssih-fix/format-string' (84b1a8cb)
    • forgot to update some makefiles (Windows search tricked me into (82d72134)
    • update the .dll names in the Release configuration too (14d98287)
  4. newclock4:
      • dvdplayer: demux ffmpeg - fix seeking behind eof (30904e0c)
      • MMAL: Use Component Logging (dd7d149e)
      • changed: Have CurlFile return m_bufferSize as chunksize (88e6ab2e)
      • scraper: Fix for losing infotags when artwork grab fails suggested by menakite (3109b0d2)
Quote:scraper: Fix for losing infotags when artwork grab fails suggested by menakite (3109b0d2)
@popcornmix - I thought this fixed a problem when scraping tvshows?
Squashed it into the original commit, so it's still there. Need to decide what to do with the season art patch.
Probably keep it in newclock4, but drop it from stable helix tree (helix_rbp_backports). Shame though - seems to work great.
OK thanks (I should have checked!) Yeah, dropping the patch is a shame but if it causes support issues... for the best.
It looks like there is a small problem with my usb wireless in the test builds. My usb wireless device
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
that was detected in stock 4.2.1 is no longer detected. I checked and the 8192cu driver is still included, and the fix is just to enable the interface in the autostart.sh script:
#!/bin/sh
(sleep 15; \
/sbin/ifconfig wlan0 up \
I don't remember where the mapping is from usb device to driver, it's probably a simple fix. The same thing is happening in the stock OpenElec beta. Does anyone have any pointers?
  • 138
  • 139
  • 140(current)
  • 141
  • 142
  • 156
OpenELEC Testbuilds for RaspberryPi Part 3 (Kodi 14.0)8
