jjd-uk
Team-Kodi Member
Sorry but you're going have to be more precise in the sort of structure you're after using actual examples, how you had it working before may have been a lucky fluke.
jjd-uk
Team-Kodi Member
2014-05-28, 16:55
(This post was last modified: 2014-05-28, 16:55 by jjd-uk.)
Would the following achieve what you want:
Track 1
Artist = Artist1 / Various Artists
Album Artist = Various Artists
Album = Test
Track 2
Artist = Artist2 / Various Artists
Album = Test
Gives:
Library - Artists:
Artist1 -> Test -> Track 1
Artist2 -> Test -> Track 2
Various Artists -> Test -> Track 1 & Track 2
jjd-uk,
I have this exact same problem where some of my compilation albums show up under artists as "various" and some get moved over to compilations even though I have them tagged the same way (artist=song artist & album artist=various). After trying a bunch of tagging combinations I had given up until I read this thread. I've now tagged all of my compilation albums with the album artist tag of ".Various Artists" and they all show up at the top of my artist list.
I read your comment above and agreed with not liking the tag of "compliation albums" because it throws these albums into the middle of the artist list where as "various artists" was close the bottom. By using the "dot" in the tag my compilations now all show up at the top of my list but still have what appears to be the name I want.
I hope this helps.
I too am running v13 and have all music tagged correctly, I recently added a few new compilation albums and a regular album and re scanned and my Various Artists disappeared. No I do not have "include artist that only appear in compilations" on. I never did. In library mode "Various Artists" appeared just like any other Artists would with logo and fanart. Now I can only view them if I back out of Artists and go to Compilations.
Same problem here.
"Album Artist = Various Artists" doesn't appear in Artists, only under Compilations in the library. (Include artists who are only in complications setting is off)
I'm not 100% convinced that it works off the Album Artist tag. Certainly in my tags, all the albums that appear under Compilations in my library have a 'Compilation' tag set to 1. Dropping or setting that tag to 0 should enable the album to be listed under Various Artists.
* I Think !! *
Learning Linux the hard way !!
2014-11-03, 20:26
(This post was last modified: 2014-11-03, 20:27 by whitebelly.)
AFAIK, compilations can be triggered from an MBID/compilation tags, or the situation where different songs have different ARTIST tags.
Simplest workaround for me is always to change all ARTIST tags to be same as ALBUM ARTIST. Of course, I don't care about the individual artists in these cases, and if you do it may not be the best approach. If I want to keep individual artist names, I leave them in comment field, filename, or elsewhere.
wazzac
Junior Member
Hi All
I have just upgraded from an early Gotham to Kodi Beta and just ran into this problem and wanted to share my frustrations in fining this change in functionality.
For at least 3 years I've used XBMC and have had my compilation albums tagged with ALBUMARTIST = "Various Artists" and the setting "Include artists who are only in complications" setting is off
This combination resulted in what I consider the ideal outcome - compilations appeared under a "Various Artists" artist in the library but the artist list wasn't swamped with heaps of artists with 1 or 2 songs listed under them.
As discussed here, the "Various Artists" entry now will not appear
It seems counter-intuitive, to have to back out of artists list and go into compilations to get to part of your music collection (as the only option)
I also see this as being confusing to guests using the system who are not familiar with Kodi
Is there a possibility that the previous functionality can be restored?
Regards
Wazza
