2014-10-12, 15:30
Seems like the slowdowns and 23,976 fps output is finally solved in latest beta firmware
(2014-06-01, 03:01)FishOil Wrote: Android based? Best XBMC ever? Not a snowball chance in hell.
(2014-06-20, 14:35)hdmkv Wrote: Do you use hd audio? Is it bitstreaming (passing through) ? What about 3D. Does it play MVC MKV and ISO's via XBMC in full (frame-packed) 3D? Thanks.
(2014-07-24, 01:18)ministerjee Wrote: well, i went with using es file explorer, and all is good now.
(2014-07-19, 04:09)majik12 Wrote: Sorry this has gone OT. Oh yeah for sure, xbmc backup tool in invaluable for this. it'll even save your menu's the exact same way you had them so you can transfer it over to any number of devices. All addons, repo's and addon data is also saved. I swap back and forth from an android and PC without any issues at all with addons, skin settings etc.
i m having another problem with my X8-H now, im connected via HDMI to my AVR (HDMI passthru is selected in minix settings), and minix 4K player shows DD/DTS playing on my AVR, but my xbmc does not show that?? is this common problem, or anyone know how to fix it.?? My xbmc audio setting only shows two settings to choose from, analog or digitalcoax /SPDIF. (note: im using the beyond XBMC version and not the minix xbmc version)
(2014-10-24, 09:30)ICUD2 Wrote: What you mean advertise? Just sharing my experience. Is that ok? I have the mini x8-h and beelink r89 the better product in my experience is the beelink r89 and its also alot cheaper so I thought maybe some people would like to know this.
(2014-06-01, 01:25)nickr Wrote: The gpl requires them to release their modified xbmc source code.
(2014-06-01, 03:26)nickr Wrote:(2014-06-01, 02:02)Phoenex Wrote:If they distribute XBMC then they are obliged to make the source available. That benefits all users because their code modifications make their way into xbmc core code and other people with similar hardware benefit.(2014-06-01, 01:25)nickr Wrote: The gpl requires them to release their modified xbmc source code.
I have no idea about XBMC gpl, perhaps you can contact Minix? I am only a potential customer looking for a powerful Android t.v. box that will work very good without major issues. I know that others are looking for the same so I created this thread. I have not ordered one myself yet. Time and testing will tell, perhaps this is the one many are looking for.
If Minix do not distribute their source then they are acting illegally. DOn't support GPL violators.
If they are distributing their source, then that is excellent!
(2014-10-24, 13:21)twelvebore Wrote:(2014-10-24, 09:30)ICUD2 Wrote: What you mean advertise? Just sharing my experience. Is that ok? I have the mini x8-h and beelink r89 the better product in my experience is the beelink r89 and its also alot cheaper so I thought maybe some people would like to know this.
He means that there is a lot of astro-turfing in this forum.
Folks who sign up just to say some really good things about some just-launched product look very suspicious, like they're being paid by the company to advertise. Don't take it personally - but it happens a lot and it is bloody annoying to the rest of us.
Quote:MINIX has now announced an updated version of their MINIX NEO X8-H android media player simply called MINIX NEO X8-H Plus, replacing Amlogic S802 by Amlogic S812, which brings support for video playback of H.265 / HEVC videos up to 4K resolution, and Gigabit Ethernet. The Wi-Fi module also appears to been upgraded to support 802.11ac.
