In my effort to get this working for Kodi 19 I'm running into issues with settings. I am unable to change the Default TTS Engine. It appears to work, but the changes don't get saved. There is other weirdness. I don't know if this is a Kodi 19 issue, or what. Investigating.
Hello. I use the latest version of kodi on android but I don't have a screen reader. After the installation, I have the sound of the launch, but Kodi Screen Reader does not voice anything. I also can't change the voice engine in the settings. Tell me what the reason might be.
Hi everyone
Some time ago I asked on reddit how a blind person used kodi. A reddit user helped me with this by telling me that using the keyboard it was possible to activate the kodi screen reader. The technique was to press A, then D and then S and press down 9 times and enter twice. The problem is that this technique does not work on the kodi 18.9 version. Is there a new way to activate the screen reader in kodi using the keyboard? Thank you all.
