  • 74
  • 75
  • 76
  • 77
  • 78(current)
Release Experimental Google Music Addon
Odd... It’s a problem I suddenly have on all my devices (iPad, iPhone, Mac and FireTV) with Kodi 17.6, 18.2 ans 18.4...
Hello,
I've been trying to build out a small setup so I can move an amp away from PC to the other side of the room. My big requirement is being able to stream an MP3 radio station and listen to GPM. I've been trying to get Kodi on LibreELEC to work on a PI 2 and a PI 4. I have to say at this point I'm very frustrated in the whole attempt. Honestly, I'm actually considering using Raspbian and VNC. Sad
LibreELEC: LibreELEC (official): 9.1.501 (RPi4.arm)
Kodi 18.4
Exp GPM version: Beta2 linked a page or two back.
Log: cujujogime.kodi (paste)
The issue stems from an earlier reported issue regarding Python and lib2to3 missing.
Does anyone have a fix for this without me having to compile something from scratch? A linked lib that supposedly solved the issue is no longer available. I'm a software engineer 5 days a week so I don't mind technical solutions but I had hoped that Kodi and its addins were a little more worn-in than what I'm seeing. I don't mind throwing in some fixes to the project if something needs to be tested. I'd really like to see this move from Beta to a stable release.
Since I'm new to HTPC/Mediacenter builds is using LibreELEC considered sub-optimal? Should I be on version 17.x of Kodi seeing that every guide makes no mention of 18? I had hoped that the Pi 4 would be up to the task but I should have reviewed other's investigations with it as I suppose that it is still too "bleeding edge" for most stuff (the screen tearing is gawd awful).
Thanks for looking. Sorry for the ranty part. Just spent the entire day trying to figure this out and I'm about at the same spot where I started (albeit most of my time was trying to get SMB working between Kodi and Windows 10).
Hi mikerjr83,
not sure this also works for the beta (I think so), but to make the google play music exp plugin (1.12) work, do the following:
in file
/storage/.kodi/addons/script.module.future/libs/past/translation/__init__.py
comment out lines 41 and 42:
#from lib2to3.pgen2.parse import ParseError
#from lib2to3.refactor import RefactoringTool
in file
/storage/.kodi/addons/script.module.future/libs/libfuturize/fixes/__init__.py
comment out line 2:
#from lib2to3 import refactor
HTH
2.0beta works fine, beta6 will not start, had no log...
small Question. It is possible to make a Option to download Music for offline use like the App Download only for Premium user
its a small request
Wink
(2019-08-12, 22:32)foreverguest Wrote: Please try this version:
plugin.audio.googlemusic.exp-2.0beta2
[font][font]Beta 1 funguje na RPi4B, LibreELEC 😀[/font][/font]
Does anyone have a zip of 'lib2to3.pgen2.parse'
The one previously posted has been removed. I can't seem to get this add on working with my account.
Log is here: ewijixopov.kodi (paste)
  • 74
  • 75
  • 76
  • 77
  • 78(current)
  • 16 Vote(s) - 5 Average
Experimental Google Music Addon516
