Solved Post-install problems
Installed, updated Java, set everything up, then next time I fire it up I get this.....
http://imgur.com/PjoMpmi
Any advice to resolve this problem would be great, as I was was just getting into using the software....cheers
there is a bug in 2.5.5 which causes the UI to throw errors if you have all columns (except the title) in the movie table hidden.
If you are able to get into the settings, just select at least a second column (like year).
If you aren't able to get into the settings - open the config.xml inside the tinymediamanager.app and delete one or more of the following lines:
<imageColumnVisible>false</imageColumnVisible>
<nfoColumnVisible>false</nfoColumnVisible>
<subtitleColumnVisible>false</subtitleColumnVisible>
<trailerColumnVisible>false</trailerColumnVisible>
<yearColumnVisible>false</yearColumnVisible>
that issue if fixed within v2.6
tinyMediaManager - THE media manager of your choice - available for Windows, macOS and Linux
Help us translate tinyMediaManager at Weblate | Translations at 66%
Found a bug or want to submit a feature request? Contact us at GitLab
Thanks that seems to have sorted it out. Cheers
Post-install problems0
