strange that both rockchip and an allwinner boxes suffer from the same bug. Wonder if its a bug in the android OS then.
Wolly
Senior Member
2014-12-01, 06:14
(This post was last modified: 2014-12-01, 06:17 by Wolly.)
Hey, guys.
The 3D iso stuttering problem is very likely to be solved in this week, and we will release the first official version of VidOn XBMC (Gotham) if it could pass all tests.
We are sorry for the inconvenience and all of our developers now are working to fix these problems.
Because of the buffering issue, my $69 device is collecting dust for now.
MY CURRENT MEDIA PLAYER |
MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
stewfo
Junior Member
Hey Wolly
Unable to get True-HD to play on my Yamaha RXS600.
I have updated to the latest SDK 1.2 and have tried both VidOn XBMC and the latest Gotham.
When I play a True-HD movie with HDMI passthrough enabled I get no sound.
Turn off passthrough and it output PCM.
File tested : hd_dts_hd_master_audio_sound_check_5_1_lossless-DWEU (1).m2ts
I have checked all the audio settings in XBMC and passthrough is set to HDMI.
This was the main reason I purchased this device, Wolly any update on the handshake issue's some of us are experiencing with certain AVR's.
Logfile sent 28/112014
Just to rule out any HDMI handshaking issues (which VidOn has with some AVR's), have you also enabled HDMI and passthrough in VidOn's settings tab?
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
stewfo
Junior Member
Yes enabled HDMI passthrough on the Vidon box. Spent quite a bit of time on this and its only True-hd etc that does not produce any audio.
Every other format plays without issue's.
Hopefully Wolly will respond with a reply to those of us who are having avr HD audio Issue's.
stewfo
Junior Member
Hi Wolly
At work just now so will check later but where do i check this:
"Please make sure you have enabled HDMI Passthrough in VMC"
HDMI passthrough is enabled in "Settings" - "Audio"
Wolly
Senior Member
2014-12-02, 11:43
(This post was last modified: 2014-12-02, 11:44 by Wolly.)
Back to home screen, navigate to Settings, then choose Audio, and you can see it clearly, just check HDMI and Passthrough in that page.
stewfo
Junior Member
Thats already checked, so it must be a compatibility problem, I have already tested it with Vidon XBMC (Gotham) and it still does not work.
Are you saying this will be fixed in Gotham final release? ( "which is to be solved in the new VidOn XBMC (Gotham)" )
When is Gotham final going to be released?
Wolly
Senior Member
Since we have migrated to Gotham, so all work will be based on Gotham, and all problems will be solved on VidOn XBMC (Gotham). The problem may not be solved in the first official version but this problem also has a high priority.
Why spend time on Gotham when Kodi Helix RC is here?
