nickr
Retired Team-Kodi Member
Yes you can - Comparison 1, does it work?
RPi YES
Vidon NO
Comparison 2: Do the authors of XBMC for the device comply with their obligations under the GPL2?
RPi YES
Vidon NO.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
nickr
You are an idiot if you think the GPL is irrelevant just because you are a user not a developer.
In copmparison 1 I am talking about the device actually working as a media centre. About the GUI working in 1080p, about all the other bollocks suffered by vidon users and revealed by this thread.
I'd rather forsake HD audio and run a machine that otherwise works, theres your comparison.
I'm worrying that Vidon XBMC is dedicated for VidonBox or whole Vidon.me devices
I tested the first alpha and it cannot run on my AV200. And my friend who is closed tester said that the second alpha is still have same issue
Seem Vidon.me left the old devices (AV200 & AV100). I believe the answer is no, else that's bad business and no one believe on you that pay the money to buy your produce
So i would like to ask, why "3D iso buffering" issue is more important (and is going to be fixed earlier) than A/V Sync issue which is far more important and is affecting all videos, not only 3D ones!? Generally speaking A/V sync issue makes VidOn Box unusable.
