phil65
Retired Team-Kodi Member
hmm could you also test '"$INFO[XXX]"' (--> single quotation mark(double quotation mark($INFO[])) and perhaps variations?
Hitcher
Team-Kodi Member
Hey Phil, could you update the first post on how to use the select dialog as it's the old method.
phil65
Updated first post (I hope I got it right).
Yes, will put it on repo when time allows it.
phil65
2015-05-20, 21:17
(This post was last modified: 2015-05-20, 21:24 by phil65.)
put together a small readme with examples for all stuff which is supported for now.
didnt have a closer look into this for some time, so please report if anything is wrong or missing:
Dialog call examples:
- DialogSelect
<onclick>SetProperty(Dialog.1.Label,SOME TEXT)</onclick>
<onclick>SetProperty(Dialog.1.BuiltIn,BUILTIN)</onclick>
<onclick>SetProperty(Dialog.2.Label,SOME TEXT)</onclick>
<onclick>SetProperty(Dialog.2.BuiltIn,BUILTIN)</onclick>
<onclick>SetProperty(Dialog.3.Label,SOME TEXT)</onclick>
<onclick>SetProperty(Dialog.3.BuiltIn,BUILTIN)</onclick>
<onclick>RunScript(script.toolbox,info=selectdialog,header=SOME_TEXT)</onclick>
- DialogYesNo
<onclick>RunScript(script.toolbox,info=yesnodialog,header=SOME_TEXT,text=SOME_TEXT,yesaction=BUILTIN,noaction=BUILTIN,yeslabel=SOME_TEXT,nolabel=SOME_TEXT)</onclick>
- DialogOK
<onclick>RunScript(script.toolbox,info=okdialog,header=SOME_TEXT,text=SOME_TEXT)</onclick>
- DialogTextViewer
<onclick>RunScript(script.toolbox,info=textviewer,header=SOME_TEXT,text=SOME_TEXT)</onclick>
- Notification with extended options
<onclick>RunScript(script.toolbox,info=notification,header=SOME_TEXT,text=SOME_TEXT,icon=PATH_TO_ICON,time=SECONDS_TO_DISPLAY,sound=TRUE/FALSE)</onclick>
Notes:
- use "|" to append several builtins
- escape stuff like following: '"$INFO[xxx]"'
other calls:
<onclick>RunScript(script.toolbox,info=exportskinsettings)</onclick>
<onclick>RunScript(script.toolbox,info=importskinsettings)</onclick>
<onclick>RunScript(script.toolbox,info=blur,id=PATH_TO_IMAGE)</onclick>
phil65
oh, sorry, error in ReadMe. try "||"
Hitcher
Team-Kodi Member
Cheers, and which one of my attempts above should I use them with?
