Hi Phil, regarding my previous request for export filter, just wonder if you can make these possible :
- Define a filename at export instead of the common skin.xxx.backup.txt
- Define a filename for import without browsing for file
The import / export works so fine that I thought about using this kind of process for first skin's startup. Your script is much faster than SetString (And I have a large amount of them) and could easily allow to build a setup at startup to allow the user to choose from wiewtypes and colorsets (horizontal / Vertical / Fullscreen / Black / White, etc ...). Files could be added to the skin's extra folder (extra/colorsets/ or extra/templates).
Something like this :
Import for startup
RunScript(script.toolbox,info=importskinsettings,path="extra/colorsets/Black_colorset.txt")
and
User defines name of export
RunScript(script.toolbox,info=exportskinsettings,text=MY_DUMMY_TEXT,prompt=true)
Thanx
