2015-05-04, 15:57
(This post was last modified: 2015-05-04, 15:59 by meridius.)
Hi there mate I am all up for that and thanks for the feedback, just let me know what you want and ill try and help out in any way I can .Would like to help to make this the best remote out there as I have tried many over the years and always keep going back to the old xbmc commander remote as all the others have many missing features or are not very well thought out
I know this will take a lot of time on your part for the programing but that's not a problem as I am always looking on here.
cheers
Aha I see I wasn't really up to date on that!
Awesome! I notice a crash from Kodi by the way if I tap EPG in the remote. Don't know if it's related to your app or Kodi itself.
2015-05-06, 23:21
(This post was last modified: 2015-05-06, 23:22 by rschiks.)
Version 1.2.1 is approved and I immediately submitted version 1.3 :-)
This version contains the following:
- New flat design icon and splash screen for the App.
- Add-ons option rewritten. You can now browse through the results of the add-ons on your device. A quick selection bar is added. Add and remove your favourite add-ons to the quick selection bar for easy selection.
- bugfixes.
There are two new options added to the Pro version:
- Flat design buttons: enjoy the flat design buttons and restyled remote control.
- Progress: keep track of your series. See in an instance your last watched episode and the next one to watch.
