2015-06-14, 14:51
(This post was last modified: 2015-06-14, 15:06 by Goliath2000.)
You are absolutely right ! Having these four categories are sufficient to cover everyone's needs with these visual icones. What I thought about was information that appears on the album , just like you show for the selected artist. The label info can be pulled out from the mp3 tag together with album info.
I am not to sure how that works as I think the remote can only pull info that kodi supports, so its a Richard question.
From post 627 It seems that there is albumlabel support. Well anyway this is just ideas, as you said Richard decide what he wants to be visual.
2015-06-14, 16:21
(This post was last modified: 2015-06-14, 16:22 by meridius.)
Hi Richard so should I add a 5th button ?
Where's the update come on Apple hear me roar. Lol
So it's a album label artwork to be displayed you mean ? If so where could you get all the artwork for them ?
Ah ok in text format. I could remove tha date in The track list as I do have it twice on the same screen so it could be added but it's up to you Richard if you want to add that in the new views I am doing.
Remember that not everyone have added this info into their Music files, so It means that usually this particular field might be empty
Yep got you but since it's at the end of the artists name it will not matter if there is no field as it will not make any difference to the layout or view and would still look good if there's no field.
Will post image later
