2015-08-29, 18:36
Ok so if i understand good, the picture is good ? :
(2015-08-29, 18:20)rschiks Wrote:(2015-08-29, 18:14)madmartigan57 Wrote: Another small question about the next remote control. If I understand it will be possible to have the top and bottom bar.
It will be possible to do like this:
Yes, it will be possible to do it like this. With one remark: the top menu bar in the remote control view does not show the menu button and the remote control button. The menu button would leave the remote control view anyway and the remote button is also not needed, since you are already in the remote control view.
The same for the two buttons in the bottom menu bar.
