  • 103
  • 104
  • 105(current)
  • 106
  • 107
  • 180
Kyra for Kodi
@meridius how is it going with the flags? Smile
(2015-09-04, 19:56)Goliath2000 Wrote: @meridius how is it going with the flags? Smile
Hello. Beleave it or not Richards just asked about that will be sorted this weekend.
flags done. please check but I think there all right from what I can see
(2015-09-05, 09:51)meridius Wrote: flags done. please check but I think there all right from what I can see
Wonderful Smile it looks OK to me! But will you be able to add more? because this is only what I have seen in many bluray disc from europe. it need to be at least around 100 countries to be fully usable for everyone
yes I can add more but want to work on other things for the remote view first as me and Richard want to get that done
heres a pic of what it will look like , the arrows at the side of the audio menu will not be there if there is less than 5 audios or subtitles
Looking at the flags I will add a setting that it will display the exact info Kodi returns maybe between (). I don't know all flags by heart :-)
Proud owner of comics42.shop
Animated posters and backgrounds, character art can be found here
Get Kyra for Kodi 2 here
Get Kyra for Trakt here
I think it is also important for the flags to match the language and not the country so that the correct one can be shown, for example Chinese instead of China, and Spanish instead of Spain. Thanks.
Regards,
Bart
(2015-09-05, 12:21)bsoriano Wrote: I think it is also important for the flags to match the language and not the country so that the correct one can be shown, for example Chinese instead of China, and Spanish instead of Spain. Thanks.
Regards,
Bart
I agree and this info is also returned by Kodi.
Is this better ?
I hope we can fill in all the "no image" because it will look bad Sad
I don't understand if the flags are there why do we need to display it in text? rschiks This need to be select-able :p
just in case you don't know what the flags are but to be honest you should know your own flag as I don't really need to know other flags as I will not be listening to that audio
but there is a design for both so its up to Richard and you all to see which one you want to use. but it does cover if there is no flag for that audio as you can see in the mono track what is it ? but if it had French under the mono you would know
(2015-09-05, 13:41)Goliath2000 Wrote: I don't understand if the flags are there why do we need to display it in text? rschiks This need to be select-able :p
See post 1566
busy with the view menu now
See post 1566
Like usual, you are always one step ahead Smile
  • 103
  • 104
  • 105(current)
  • 106
  • 107
  • 180
  • 8 Vote(s) - 4.25 Average
Kyra for Kodi4.258
