2015-10-26, 22:15
(2015-10-26, 22:02)bsoriano Wrote: Richard,
Will the XL options be in 1.9?
Regards,
Bart
Yes, both the movies xl and series xl. And the iPad Pro support.
Regards,
Bart
(2015-10-27, 20:43)Goliath2000 Wrote: @rschiks sometimes when I scroll through my music I get some strange artifacts in the music view. Have you also seen it? some artist thumbnail starts to flicker
(2015-10-27, 21:16)rschiks Wrote:(2015-10-27, 20:43)Goliath2000 Wrote: @rschiks sometimes when I scroll through my music I get some strange artifacts in the music view. Have you also seen it? some artist thumbnail starts to flicker
No, not really. And I have seen (and used) the music view a lot. Are you sure you don't have a hardware issue?
Also because earlier your iPad froze several times?
(2015-10-27, 21:38)rschiks Wrote:(2015-10-27, 21:16)rschiks Wrote:(2015-10-27, 20:43)Goliath2000 Wrote: @rschiks sometimes when I scroll through my music I get some strange artifacts in the music view. Have you also seen it? some artist thumbnail starts to flicker
I was just thinking: could it be that the cdart is still rotating underneath, so is the problem on the right side of the screen?
(2015-10-28, 18:50)Goliath2000 Wrote:(2015-10-27, 21:38)rschiks Wrote:(2015-10-27, 21:16)rschiks Wrote: No, not really. And I have seen (and used) the music view a lot. Are you sure you don't have a hardware issue?
No I don't believe it is a hardware issue! To problem occurs on left side of the screen. I have seen it on the first poster or maybe it was on the first one on second row.
(2015-10-31, 13:09)MrLondon Wrote: Cannot wait will be great, just a quick question in the official remote control when you press play it gives the option to play the trailer for the movie can you also add this? Normally it's the trailer on YouTube
(2015-10-31, 19:44)Goliath2000 Wrote: @rschiks can't be better than this
