Looking really good Richard, thanks!
The "Albums from artist" are those that are in Kodi's Music Library, correct?
Regards,
Bart
Very soon I am beginning with the search option for the iPhone version. This is not the same as the search in Kodi option the iPad version has. With the search option you can find movies (themoviedb.org), series (thetvdb.com) and people (also from themoviedb.org). I personally find this a very handy feature. It also allows me to search for an actor when clicked on one and find out in what series and movies he/she played.
In the iPad version it's integrated with trakt.tv. Something I don't want to put in right away.
It's suggested by someone (a long time ago) to add data from Kodi to the results. So when you look for a movie, the results will also display if you have it in your library and seen it. The same for series of course.
Is this something still on the wanted features list? And should it do even more?
PS:
The search in Kodi will also be there. The difference with the other search option is that you can search for a keyword in the Kodi database.
Hi There,
i have a feature request for the new IPad/Iphone version:
would be nice to preselect Movie/Show list by genre, to scroll through just a specific genre / Artist / director
Genre would be my favorite. other preselection might be good for other users :-)
Best Regards
Hi Richard,
I see this more as a generic filter to an existing list (regardless of Movie or show) so i would vote for a seperate item on the menuebar.
understand the speed concerns, especially if you look at the amount of actors you have to fetch for big libraries (this could easy grow beyound 64K of actors :-) ), maybe here the user should be able to enter free text, before you fetch all actors and display a list :-), the statement will be valid for directors as well.
for Genres it should be a fair asumption that you keep the list small.
just my 2 cents
Best Regards
Hi Richard,
that's correct genre is a search option in Kodi, or better to scroll through movies by genre (not sure if this is valid for TV shows).
if you like to do that in Kyra (not on the screen) you might get the existing genres throgh the api, but not sure.
Best Regards
Hi Richard,
For some reason my Movies only generates the same view as the Recently Added movies, displaying the 25 latest. It was working before but today it wasn't.
In the settings I have enabled caching and I haven't replaced Movies with Movies XL. Btw Movies XL is showing all my movies.
Any ideas?
