dseto
Junior Member
Not sure if this is the right place for this question, when using the plex app from kodi, and i select a movie that has both a 2k and 4k version to choose from, no issues when selecting the 2k version, it opens mpc-hc and plays, but if i select the 4k version it open the mpc-hc, but doesn't start. if i manually click the file in windows for the 4k version it opens mpc-hc and plays.
would this be a config issue with the playercorefactory, or is this an issue with mpc-hc, thoughts?
I'm not sure. You would have to post your complete playercorefactory.xml. It could be that or an issue with MPC-HC.
If you use MPC-BE's refresh rate switcher, you can add a delay with each refresh rate change. That is the only way that I can think of.
Right, I see. I am using madVR to change refresh rates currently but might give mpc a try.
I don't know what to do anymore, today I tried to uninstall BE and put MPC-HC with various changes to the XML file I always have the same problem, going to watch a video for a few minutes and then stopping back to the kodi menu I quickly scroll through the files and click on a film that interests me the pc freezes having to restart the system. I do not think the PC is to be formatted also because if I use the internal player there are no problems. Can there be something to set in the Kodi options? An addon to install? I use Win10 and Kodi 18.7.
2020-06-15, 11:41
(This post was last modified: 2020-06-15, 11:41 by Warner306.)
Have you tried going back to MPC-BE instead of MPC-HC?
If XySubFilter doesn't show up on the list of filters during playback, it likely isn't installed or isn't installed correctly. Check to see if you installed the 32-bit or 64-bit version. That should match with the 32-bit or 64-bit version of MPC. That is most common mistake made with XySubFilter.
If you downloaded the correct version of XySubFilter, try reinstalling it.
2020-06-25, 12:41
(This post was last modified: 2020-06-25, 13:28 by Cinephile.)
Looks like Nvidia's new 451.48 driver broke madVR HDR functionality? Apparently, they changed HDR behaviour with this updated driver which is likely going to be adopted for new drivers moving forward. Here is hoping Madshi can release a fix.
2020-06-25, 23:08
(This post was last modified: 2020-06-25, 23:09 by Warner306.)
Yes, I did hear that. Someone posted directly to madshi at another forum. Chances are he will provide a fix in the next build, whenever that might be.
If you are using recent Nvidia drivers, stereo 3D support has been removed by Nvidia. Is that the issue?
