Hope this question is allowed. If not please delete the question. Thank you. It's from the Silvo 6.1.6 (Leia) skin. Below is code I copied from the 16x9/Defaults.xml
<default type="textbox">
<left>0</left>
<top>0</top>
<width>615</width>
<height>322</height>
<align>left</align>
<textcolor>white</textcolor>
<font>font15_textbox</font>
</default>
I've found the two screens which uses font15_textbox. What I can't find is where within the skin uses this block of code to change the font displayed on the screen. I've searched the skin for "textbox" but this hasn't helped. I'm trying reading how to use .xml but barely have an understanding at this time. Could someone please point me to where this code is used? thank you.
Hi Karellen. I can change the font. What I meant to say is that font in the piece of code sets the font used in two different areas. What I would like to do is separate the two areas and use a different font in each. Right now I can't do that because they are both controlled by this one piece of code. I'm trying to find out what this piece of code controls (if any) so that I can try to separate them into two different fonts. thanks for asking.
Ok. Screenshots with the areas you want to modify circled will help. It might not be me that will help out, but maybe others can.
Mahava
Junior Member
@ brazen1
I'm using nox: Silvo for Kryton on a Windows 10 PC
I'm a novice, but from what I understand, Next Aired displays only 1) TV Shows, 2) TV Shows that you've added to your library, and 3) TV shows that are in your library and currently airing. If you have those three things, then it should display them.
Artwork Beef alone will work, and I think this skinner has recommended that you use that, and not use Artwork Downloader. Even when I don't have artwork, my airing shows will display.
Scan some airing shows into your library, add the folders as video sources, and update your library and it should work. If it still doesn't work, I'm afraid I don't know why.
I'm using KODI v.18 Leia but thanks for your clarification.
2018-12-18, 02:08
(This post was last modified: 2018-12-18, 02:10 by Saschi.)
Hello specialists,
meanwhile I found out most of it myself
my icons on the homescreen above the navigation bar
I could create and work this way too
as I want it. BUT unfortunately these are with a white one
ugly cross underneath the name of the icon. How to get
I have a picture in it, for example, a logo or something.
Greeting Saschi
Comma
Senior Member
Request for adding a option in the Infowall view to show landscape.jpg instead of fanart.jpg,
but only the small image on the right side above the description I think this would look very nice, hope you would consider this.
If it's not too complicated since I have no idea what going on behind the curtain I would appreciate the guidance to do it myself.
Thanks this great skin and Merry Christmas to all of you.
