Since Build #0117 every time I unplug my rpi and replug the cable, system falls in debug shell. It says that the fs couldn't be repaird automatically and I must run fsck by myselfe. fsck corrects the fs and system boots. Can repeat the "error" every time if needed.
Milhouse
Retired Team-Kodi Member
Nothing different in #0117 with respect to system startup... suspect your SD card has finally had enough of the power being yanked.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Hmm the point is, that with #0116 there is no problem, when I unplug and replug the power. Only #0117 has the issue with corrupt fs for me.
Milhouse
Don't know if the new kernel could account for the new behaviour, perhaps if it were now a bit more finicky with certain file systems? Try fsck'ing your SD card in a Linux PC.
a debug log may also shed some light on it
Milhouse
Not sure what sort of controller you are referring to, but these builds have the same "controller" support you will find in upstream OpenELEC master.
Hi. A few builds back the gpio ir sensor was working good with normal RC6 remote. Now when using it, one key-press causes two presses so it can not be used. The good news is that gpio was not working on RPI+ (build 14. dec) but on jan 19 build one works but causes two key-presses on both RPI models (+ and older one with 512mb ram).
