2015-10-12, 17:03
(This post was last modified: 2015-10-12, 17:03 by Wanilton.)
2.9.0 - Isengard version, don´t release by MarcosQui yet.
It´s work with any skin, I use this resource since 2014 (helix generation).
I don´t try yet, but I have 99.99% work ok. I verify htpc brazen1 via teamviewer,he´s using nox and work too. He´s have trouble, but not with animated arts, more relationed with use Artwork Downloader addon.
2015-10-12, 22:34
(This post was last modified: 2015-10-12, 22:41 by brazen1.)
Many thanks to Wanilton. Yes, the animation works fine using latest Jarvis nightly with Madnox or Confluence or most likely any skin for that matter. My specific problem is Kodi showing 2 posters for the same movie even though the original was deleted and replaced with the new poster.gif.
My system is completely automated for all artwork.
I tried a few things to stop the old poster.jpg from populating the cache even though it no longer resides next to the movie in its folder:
Deleted from movie folder. It never got downloaded back in either.
Deleted via context menu.
Cleaned library.
Ran texturecache utility with command lines P, R, and c ALL.
Unchecked d/l poster art within tmdb and universal artwork downloader. Also unchecked thumbs.
Removed title from local storage.
Did all of the above restarting Kodi many times in between.
Added title back to local storage.
Scanned title into Kodi.
2 posters again for same movie. There is still only one poster in title folder.
Giving up for now.
P.S. Wanilton showed me his library. He does not have this problem so I know it works 100% correctly. I'm sure if I started from square one all would be fine but that's a last resort not happening anytime soon afaik.
you need decompress texture.xbt file actual (media folder), and compress again, after only need overwrite texture.xbt actual with new.
2015-10-13, 01:56
(This post was last modified: 2015-10-13, 01:57 by Wanilton.)
Go to addon folder, check skin.aeonmq6, media folder, you see Textures.xbt, decompress with tool, next step compress again using same tool, and replace.
