Hotlinks to various Hardware threads (updated May 2020)
This is by no means a comprehensive list... but here are some links to popular forum threads for XBMC hardware:
NOTE: Alternatively you can also check out the wiki which has lots of info on the devices http://kodi.wiki/view/Devices
We don't recommend one hardware device over any other.
Amazon
2020 - FireTV Stick 3 & Lite (1080p) - https://forum.kodi.tv/showthread.php?tid=357265
2019 - FireTV Cube v2 - https://forum.kodi.tv/showthread.php?tid=347239
2018 - FireTV Stick 4K - https://forum.kodi.tv/showthread.php?tid=336151
2017 - FireTV (Gen3) 4K HDR pendant - https://forum.kodi.tv/showthread.php?tid=322081
FireTV 2 4K - http://forum.kodi.tv/showthread.php?tid=239126
FireTV Stick - http://forum.kodi.tv/showthread.php?tid=207444
HardKernel
ODROID C4 - https://forum.kodi.tv/showthread.php?tid=353791
ODROID N2 - https://forum.kodi.tv/showthread.php?tid=340809
ODROID C1 - http://forum.kodi.tv/showthread.php?tid=210987
ODROID C2 - http://forum.kodi.tv/showthread.php?tid=258707
Khadas
VIM3L HTPC Kit - https://forum.kodi.tv/showthread.php?tid=349042
NVIDIA
2019 Shield Android TV Pro / Stick - https://forum.kodi.tv/showthread.php?tid=348500
2015 / 2017 - Shield Android TV - http://forum.kodi.tv/showthread.php?tid=304226
MINIX
NEO T5 & NEO U22-XJ - https://forum.kodi.tv/showthread.php?tid=347144
NEO U9-H - http://forum.kodi.tv/showthread.php?tid=308251
NEO X8-H - http://forum.kodi.tv/showthread.php?tid=196670
NEO U1 - http://forum.kodi.tv/showthread.php?tid=250284
Ematic
2018 - Jetstream 4K Ultra HD / Engel EN1015K - https://forum.kodi.tv/showthread.php?tid=336728
Raspberry Pi
Raspberry Pi 1 - http://forum.kodi.tv/forumdisplay.php?fid=166
Raspberry Pi 2 - http://forum.kodi.tv/showthread.php?tid=217063
Raspberry Pi 3 - http://forum.kodi.tv/showthread.php?tid=262206
Raspberry Pi 3 (B+) - https://forum.kodi.tv/showthread.php?tid=329654
Raspberry Pi 4 - https://forum.kodi.tv/showthread.php?tid=344891
Xiaomi
Mi Box (S) - http://forum.kodi.tv/showthread.php?tid=275083
Vero
Vero 1 - http://forum.kodi.tv/showthread.php?tid=209785
Vero 2 - http://forum.kodi.tv/showthread.php?tid=254304
Vero 4K - http://forum.kodi.tv/showthread.php?tid=307980
Apple TV 4K - https://forum.kodi.tv/showthread.php?tid=335219
Zidoo
X9S, X8 & X10 - https://forum.kodi.tv/showthread.php?tid=291943
Chromebox
Asus/HP/Dell/Acer - http://forum.kodi.tv/showthread.php?tid=194362
HiMedia
Q5 (2014 edition) - http://forum.kodi.tv/showthread.php?tid=207730
Q5 & Q10 pro (2016 edition) - http://forum.kodi.tv/showthread.php?tid=265888
NVIDIA GeForce GT 1030 graphics cards
Perfect for low cost budget 4K (Windows) HTPC - https://forum.kodi.tv/showthread.php?tid=318937
AMD Ryzen
Placeholder for AMD Ryzen processors - https://forum.kodi.tv/showthread.php?tid=308153
Core i NUC 2017 - Kaby Lake (7th Generation CPU) - http://forum.kodi.tv/showthread.php?tid=306556
Core i NUC 2015 - Skylake (6th Generation CPU) - http://forum.kodi.tv/showthread.php?tid=258088
Core i NUC 2014 - Broadwell (5th Generation CPU) - http://forum.kodi.tv/showthread.php?tid=214018
Core i NUC 2013 - Haswell (4th Generation CPU) - http://forum.kodi.tv/showthread.php?tid=176718
Core i NUC 2012 - Ivy Bridge (3rd Generation CPU) - http://forum.kodi.tv/showthread.php?tid=140534
Celeron NUC 2015 - Braswell (5th Generation CPU) - http://forum.kodi.tv/showthread.php?tid=227882
Celeron NUC 2013 - Bay Trail (4th Generation CPU) - http://forum.kodi.tv/showthread.php?tid=187433
Compute Stick 2016 - Cherry Trail - http://forum.kodi.tv/showthread.php?tid=261371
Compute Stick 2015 - Broadwell - http://forum.kodi.tv/showthread.php?tid=214016
Core 4K - http://forum.kodi.tv/showthread.php?tid=238923
Play - http://forum.kodi.tv/showthread.php?tid=213747
Hub - http://forum.kodi.tv/showthread.php?tid=280406
Play 2 - http://forum.kodi.tv/showthread.php?tid=263373
Cyclone X4 - http://forum.kodi.tv/showthread.php?tid=208233
Zotac
CI320 - http://forum.kodi.tv/showthread.php?tid=196823
B1320 - http://forum.kodi.tv/showthread.php?tid=211925
Solidrun
Cubox i - http://forum.kodi.tv/showthread.php?tid=172726
Gigabyte
Brix - http://forum.kodi.tv/showthread.php?tid=162269
Asrock
Beebox - http://forum.kodi.tv/showthread.php?tid=227363
HP
260 G1 - http://forum.kodi.tv/showthread.php?tid=229668
Sony TVs
Bravia TV (2015) - http://forum.kodi.tv/showthread.php?tid=229348
Bravia TV (2016) - http://forum.kodi.tv/showthread.php?tid=281265
Philips TVs
Philips TV series (2016) - http://forum.kodi.tv/showthread.php?tid=259883
In my opinion, a better list would be the devices that are 'supported', and by 'supported' I mean the ones that the dev's are currently using in their own environments, as they will be the most tested and functional devices.
(Yes, supported is a poor choice of wording... my brain is not in full gear to think of another way to put it yet.. Sorry!)
One of these days people will start using the wiki...
Devices (wiki)
(2015-01-26, 17:07)Ned Scott Wrote: One of these days people will start using the wiki...
Devices (wiki)
Thanks, updated 1st thread.
Devices (wiki)
From the WIKI:
Quote:It is highly recommended for users to not make any purchases in anticipation of running XBMC/Kodi on Android without first researching the device you want to buy. Before you do buy, make sure multiple people have verified that it works! If in doubt, do not buy that hardware!
A central place for 'verified' hardware would be good though. For example somewhere in a thread, I have no idea what topic it was except it was under Android support, you posted a comment and a link about a little wireless stick (like the fireTV stick) that you said worked very good (at least I am pretty sure it was you). Since you are a team member, that recommendation holds a little more water than from a regular user. However, trying to find that post is like finding a needle in a haystack.
This guy? http://www.geekbuying.com/item/MK808B-Pl...37068.html
Pretty much any of the M805-based devices seem to be awesome for the price (all of the normal codecs and HEVC? nice). You can also get the ODROID-C1 and it's basically the same thing, but you get more USB ports, ethernet, and IR on the ODROID.
(2015-01-26, 18:25)Ned Scott Wrote: This guy? http://www.geekbuying.com/item/MK808B-Pl...37068.html
That's the one! Thanks... now to decide if I'm going with that or just a FireTV stick.... I may get one of each and play!
(2015-01-26, 13:50)zag Wrote: Chromebox
HP/Dell - http://forum.kodi.tv/showthread.php?tid=194362
Asus - http://forum.kodi.tv/showthread.php?tid=185329
All 4 ChromeBoxes (Asus/HP/Dell/Acer) should link to the wiki page and the first thread; the 2nd is outdated and should be closed/left to die
I wouldn't describe the Baytrail NUC as 4th Generation Celeron CPU, it's simply the Baytrail NUC, or the first Generation Baytrail CPU.
| myHTPC |
(2015-01-27, 23:16)-DDD- Wrote: I wouldn't describe the Baytrail NUC as 4th Generation Celeron CPU, it's simply the Baytrail NUC, or the first Generation Baytrail CPU.
Yeh I did wonder that but Intel describes it as 4th generation Atom Processor so I'll keep it that way for now.
It came out about the same time as the Haswell processors so its useful to know the timelines in sequence.
IMHO if this is to be a sticky then the original post need to be sorted after CPU architecture and hardware platform, (and preferably supported OS too), but not manufacturer or brand.
Intel NUC, Chomebox, and Zotac for example all uses x86 CPU architecture and then might have same or different CPU models.
Most other currency listed in the original post uses ARM CPU architecture but chipsets from different manufacturers and models, and some supporting Linux and others Android.
Anyhow, the CPU architecture, hardware platform, and supported operating systems are much too important to know.
Better example of this type of sticky is eskro's list which first looks a users demands, needs, and wants/wishes http://forum.kodi.tv/showthread.php?tid=94199
Like for example if Netflix is a must then that quickly narrows it down, and so does PVR, physicial DVD-Video or Blu-ray Disc media support, and gaming requirements.
How important is price, are you on a clearly limited budget, and so on.
Also checkout poofyhairguy's thread on HTPC recommendations http://forum.kodi.tv/showthread.php?tid=94268
It's the first time i saw this called this way. With 4th Generation i would imply that with 4th Generation Core-I Processors like Haswell,
but this both Product Lines are completely different (Atom vs. Core-i / Gen7 IVB GPU vs Gen8 HSW GPU).
When you want to keep this, i would replace Celeron or add the "Atom" to the Description to be more precise and to separate it more from HSW.
| myHTPC |
(2015-01-28, 21:59)-DDD- Wrote: It's the first time i saw this called this way. With 4th Generation i would imply that with 4th Generation Core-I Processors like Haswell,
Sure, done
(2015-01-28, 23:10)zag Wrote: Sure, done
while you're at it, might want to add the 'Haswell (4th Generation CPU)' notation to the ChromeBox as well
Good post OP!
I think the FireTV box needs some consideration. I like it MUCH better than the stick for Kodi use (more CPU for better skins, plus ethernet!). It is on sale now. Out of the difference Chromeboxes I like the Asus one best. It is easy to hack into Openelec mode and the M004U model is fanless with JUST enough CPU power to decode almost anything. The Acer shouldn't even be considered with the whole write-protect screw issue.
Good job!
Hotlinks to various Hardware threads (updated May 2020)9
