Yes, it do the job. In Zotac AD02 at least. Tomorrow i see it in Revo.
PD: I do not touch these setting or file. Is a normal installation next->next->next->run
mmm
I format HD when install win10
Movies are in NAS with .nfo
I do not understand nothing
Shine
Senior Member
I'm always using true full screen. The problem happens when using true full screen as well as full screen window, though.
2015-06-17, 22:00
(This post was last modified: 2015-06-17, 22:02 by Ed76.)
yes, i have also seen that entry in the log files. but what does it mean exactly? what can i do? are you sure amd cards doesnt support deinterlacing with dx11? i cant believe. i played a little with deinterlacing setting within catalyst but without success.
2015-06-17, 22:47
(This post was last modified: 2015-06-17, 22:48 by Ed76.)
ok, maybe i try the newest beta driver for win 8.1. win10 is to experimental/unsafe for me at the moment because this is the htpc in our living room. i will report the results.
