Well I don't know exactly why you faced with this. I haven't get this on my Intel HD4600 which is less powerfull than yours, but I have the same effect on my HD2000. Try to play with settings in NVidial Control Panel.
Just as info:
The DX11 build fixes video freezing with TV recordings and LiveTV TS when seeking and play/pause.
This issue was persisted in 14.2, 15b1 and 15b2
If background info is needed please tell me.
With this tests versions everything seems fine but no matter the skin i cannot control in pvr the channel numbers. Normally in argustv i set there the order and i choose in livetv section to follow the pvr backend numbering but its a no go. If i try with kodi channel manager to rearrange the channels i end up with all the channels with 0 number.
What i don't know is if this is a isenguard problem generic or this specific version here.
For the rest all seems fine and faster with a bit of pixelating in sd channels (nvidia 970 latest drivers)
There's no substitute for experience
Shine
Senior Member
Afaik, this advanced setting just enables the HQ PS scalers in DXVA rendering mode, ie. it controls whether the setting "Enable HQ scalers for scaling above ..%" has any effect at all when using the DXVA renderer.
The "DXVA-HD" renderer is DX9 technology, isn't it? So I guess you won't find it in a DX11 program :-)
Shine
Senior Member
2015-06-26, 22:12
(This post was last modified: 2015-06-26, 22:13 by Shine.)
Guess I'm wrong then... Anyway, I can only see DXVA as well (Intel HD 4600 and Intel G45).
jjd-uk
Team-Kodi Member
Was there any 100% reliable way to replicate the problems with the HQ scalers, I've never used them but have 2 PC's with Nvidia I could test on.
