This weekend our forum will be unavailable for a few hours due to maintenance.
How to make a shortlist of movies to choose from in Kodi?
Question
Hi all,
Something I've been wondering how to do for AGES is how to add several films to something like a "Movie Night List" of films, from which to then choose what to watch.
The only way I've found is to create a Tag, then "tag" several movies, then go browse that Tag to see the list.
The ideal for me would be to be able to manage a few custom lists of films (e.g. "Movie Night with the Boys", "Halloween Movie night", etc.) and perhaps even add a link to one of these list from the main/home "Movies" menu screen.
Does anyone know of a way (or Add-on) that can do this? Seems like a fairly standard feature.
Many thanks! Smile
One option would be to mark the videos as Favorites. Perhaps a better option would be to create seperate source folders for each category. Then create smart playlists based on file location. All you would need to do is place the video file in the appropriate folder.
ASUS Chromebox M004U (LibreELEC 8.2/Aeon Nox SiLVO)--->HDMI--->Onkyo TX-NR646--->HDMI--->Panasonic P65VT30
Thanks wgstarks, Favourites seems to be the only real option out-of-the-box.
I should've said that, ideally this should all be doable by the TV remote. For example, casually going "What shall we watch tonight?" then scrolling through the entire list of films and essentially adding some suggestions like you would to an online shopping basket. Only for your significant other to then browse your shortlist and go "Nope, nope, nope..." Rofl
What I find annoying about Favourites (at least in the Amber skin), is that they don't show like normal movie lists; they show as film covers, that's it - no plot, rating, etc. Undecided
Not really familiar with Amber but can't you change the view in the left menu?
You could use Super Favourites to create folders for each list and then add links to the movies in each relevant folder.
Thanks spoyser, will give your add-on a go! Wink
Just thought I'd awaken this thread as I stumbled across a Shortlist addon for Kodi on Reddit, but the thread is closed and I cant seem to find anything else about it. Has anyone else used it, or come across another similar?
https://www.reddit.com/r/kodi/comments/c...=post_body
https://github.com/Gothicawakening/plugi....shortlist
Looks ideal for those times where you're trying to find something to watch and want to create a shortlist to choose from.
I forked https://github.com/Gothicawakening/plugi....shortlist and adjusted for Matrix (and some python code cleanup) to work with Matrix.
It is working for me, if anyone is interested, it can be found at:
https://github.com/kcook98765/plugin.program.shortlist
(2021-05-01, 01:20)kcook_shield Wrote: I forked https://github.com/Gothicawakening/plugi....shortlist and adjusted for Matrix (and some python code cleanup) to work with Matrix.
I just tested the latest version, seems great so far. I had tested the previous GitHub version and had to go back to Ver 0.0.2 (it was only showing one movie in the list, when the were 6 or more).
Thanks again for the Matrix update.
Matrix 19
Aeon Nox:Silvo
Rapier 12.2.16
Nvidia Shield 2017
How to make a shortlist of movies to choose from in Kodi?0
