2015-03-10, 22:07
(This post was last modified: 2015-03-11, 03:28 by Warner306.)
Edit...My question was whether Smart Hub allowed control over Kodi via its web interface. The answer is no. However, Smart Hub-enabled remotes are purported to offer improved performance in reducing latency over older remotes when sending commands by IR.
Just a quick question. After I've set up the Harmony Remote to start tv, switch to kodi etc. Can I then use the same Harmony Remote to control kodi?
@ Warner306,
You're absolutely right. It's best to use both. I was thinking about the case when you have to choose between the two, when you've reached the devices limit (7 or 8 with the Harmony 700 or 650).
Thanks for your great guide. Really helped me to setup my Logitech Harmony Touch remote.
On your guide, you speak about "alt+F4" to close directly Kodi. Official command is "ctrl+end". Is there a way to add this via the harmony software or to change the shortcut in kodi? (right now i'm trynig to find a solution)
Great thread, really. But why a XBMC profile already exist on the Logitech database? It's just a question...
