2015-10-11, 01:36
Not playing in 3D if you name the filename with .3D.SBS for SBS for example?
(2015-10-11, 01:36)hdmkv Wrote: Not playing in 3D if you name the filename with .3D.SBS for SBS for example?
(2015-10-11, 02:36)wesk05 Wrote: This is how my 3D movies play on RPi2 build #1009. These are full SBS (3840x1080) or full TAB (1920x2160). I have checked it on two Sony 1080p TVs, Samsung 4K TV and Epson 5020UBe. I have checked at least 4 different builds after 0916. I haven't had much luck with 3D ISOs also.
(2015-10-11, 02:59)Milhouse Wrote: Can you post a full debug log (wiki) in the RPi testbuild thread?
A sample file may also be required if not obvious what is wrong from your debug log (I'll let popcornmix ask for that).
(2015-10-11, 10:09)langostino Wrote: What do you think about realtek 1195 boxes based, as ew902 for example?
(2015-10-11, 12:17)movie78 Wrote:(2015-10-11, 10:09)langostino Wrote: What do you think about realtek 1195 boxes based, as ew902 for example?
Its OK.
You need to mount the Network drive with a script(password protected drives works)
You can get a cheap Realtek M-195 and flash the firmware with a Eweat firmware.
The Himedia picture quality is much better than the Realtek.
(2015-10-11, 17:54)Kendos Wrote: Hi,
Im using now a Raspberry Pi 2 with OpenElec 5.95.5.
How can I play MVC ISOs?
MVC MKVs works without problems but I cant make a mkv with a specific movie at 99% an error occurs and thats all.
I tried to rip it to a iso on pc and than use MakeMKV, let MakeMKV rip the bluray, but always the same error at the end.
(2015-10-11, 16:41)langostino Wrote:(2015-10-11, 12:17)movie78 Wrote:(2015-10-11, 10:09)langostino Wrote: What do you think about realtek 1195 boxes based, as ew902 for example?
Its OK.
And what do you think about rk3368 and amlogic s812 video quality compared to Himedia q5 (hisilicon doc)
(2015-10-11, 19:33)Mylo75 Wrote: Yea the pi2 is great, it can do everything.
I still can't find a better replacement, that has more power and memory, and still can do all the pi2 can do.
(2015-10-11, 21:08)hdmkv Wrote:(2015-10-11, 19:33)Mylo75 Wrote: Yea the pi2 is great, it can do everything.
With latest builds, Pi2/Kodi is crashing after 3D ISO playback, or UI isn't coming back (no signal reported by display) after stopping playback. I'be tried builds #1009 and #1010. Going to try first build with ISO support (#0916) tonight when I have some time.
