2015-08-30, 01:59
@XTrojan, mine is intel HD 4600, and have same trouble.
(2015-08-30, 01:59)Wanilton Wrote: @XTrojan, mine is intel HD 4600, and have same trouble.
(2015-08-29, 22:27)Warner306 Wrote:(2015-08-29, 14:23)JonnyVee Wrote:(2015-08-28, 23:22)AppData Wrote: Okay, I finally figured out the new version and got the ffdshow working again and now have SVP, beautiful picture now!
Can you explain how you got FFDShow and SVP working with Kodi DSPlayer?
Toggle Filters management to Media rules and Filters configuration and install FFDShow. You will have to install and add external copies of LAV Filters and XySubFilter.
Lastly, set-up media rules for each file type using LAV Splitter, LAV Video, LAV Audio, XySubFilter and FFDShow RAW as an Extra filter. Basically, you need to use external filter packs with manual configurations.
Instructions on how to add filters and media rules here: 1966557 (post).
(2015-08-30, 03:06)JonnyVee Wrote:(2015-08-29, 22:27)Warner306 Wrote:(2015-08-29, 14:23)JonnyVee Wrote: Can you explain how you got FFDShow and SVP working with Kodi DSPlayer?
Thank you for pointing the way, but i can't seem to figure this one out. Are you able to take some screenshots specific for FFDshow? I already have SVP working in MPC.
(2015-08-30, 15:29)lSi123 Wrote: "Thank You" for your "Help"
I find out by myself why i only got a uncontrolable Playback Window (no Fullscreen) with the new DSPlayer.
New DSPlayer is not working without madVR !
I only use LAVFilters without madVR before ... works fine with 15.1 RC1
Installed madVR .... new DSPlayer is working ...
(2015-08-29, 21:54)Wanilton Wrote: @aracnoz, try with new exe, but same trouble. look video, with confluence skin happen too.
Without playing work ok, playing itself ok too, but if came back to library or home with video running, happen trouble.
1920x1080 60hz
If you need check I have teamviewer here.
(2015-08-29, 23:46)Warner306 Wrote: I tried the test build and still have an issue with the menu elements blinking. All overlays are flashing during playback. Switching the GPU flush values and presentation path from DX11 to DX9 doesn't seem to make a difference.
My set-up with a Nvidia GPU does not have this issue.
Intel HD 3000
Windows 10
madVR v0.88.21
Direct3D 11 for presentation
fullscreen exclusive mode / windowed mode
No refresh rate switching
Kodi madVR GUI enabled
Log: http://xbmclogs.com/pckivd75b
(2015-08-27, 10:38)IT007 Wrote: Further testing revealed that I now get random freezing with sound playing and Kodi totally unresponsive. Oh well, back to build 15.0 again.
Setup: Windows 10, Kodi Dsplayer 15.1 DX11, Madvr, Lav Filters, Reclock, Xysubfilter, ffdshow Raw, SVP (frame interpolation)
(2015-08-28, 12:27)aracnoz Wrote:(2015-08-28, 01:02)oldpoem Wrote:(2015-08-27, 23:39)aracnoz Wrote: are you able to reproduce this with all the skins? have you tried confluence?
I'm on confluence. Haven't installed other skins lately. I can play file with dvdplayer and download subtitles normally just not with DSplayer.
i need more details because it's really crazy this thing, how do you download the subs? by clicking here?
(2015-08-30, 17:30)alturismo Wrote: Hello,
i would like to test the ds player build but have some questions before starting
setup is an mediaportal server and a windows 8 client, 2 different mashines.
the client for ds player version is using an GTX 960 GFX card, TV sony 4k, also display set to 4k.
When i read the topic do i understand correctly that i need to replace and change the tsreader.ax on the server, why i ask is i have also
2 rpi2 running and webmediaportal ... also accessing the tvserver, and i dont want to breake all these ...
and if its not necessary, would it be enough to install lav filters and install the kodi ds version or really all the setup in topic described is necessary ?
thanks ahead.
