18 Nov 2019- TVDB are still in the process of fixing a number of bugs that have broken the TVDB scraper and any add-on that relies on TVDB data. TVDB are still working to rectify the problems.
  • 213
  • 214
  • 215(current)
  • 216
  • 217
  • 501
I have an approx. 5 second delay before audio begins (video starts, audio is in sync once it begins) when using DSPlayer or MPC-HC. Is it possible to add a delay to the video portion to allow both to begin simultaneously?
(2016-03-23, 02:59)maddiesdad15 Wrote: I have an approx. 5 second delay before audio begins (video starts, audio is in sync once it begins) when using DSPlayer or MPC-HC. Is it possible to add a delay to the video portion to allow both to begin simultaneously?
Did you try another audio renderer? sanear could be an option. It is very simple. ReClock uses a large pre-buffer (which can be reduced).
(2016-03-22, 02:26)Warner306 Wrote:
(2016-03-21, 21:52)brucethemoose Wrote: Does anyone else have problems with DVDs?
DSPlayer works fine with local videos off the hard drive as well as streams... but whenever I try to play a DVD with the latest DSPlayer build, it just uses the default Kodi renderer.
ISO support is lacking. DVD discs...I don't know. You might be better off using MPC-HC.
MPC-HC hangs with this DVD... It's a retail copy of Avatar Book 3, so I don't know why :/
Works fine with PotPlayer, but PotPlayer doesn't like SVP for some reason.
(2016-03-05, 03:00)Wanilton Wrote: Kodi Jarvis 16.1 RC1 + dsplayer * (03/04/2016)
link for download:
https://dl.dropboxusercontent.com/u/7799...5.dx11.exe
Update internal lav filters for version 0.67.0-142 (03/03/2016).
Warnings:
- This is an unofficial Kodi build not from Team Kodi.
- This build comes with no warranties, explicit or implied, and you use it at your own risk.
- This build was compiled by Wanilton, for use only in Windows OS, and have same functions official Kodi Jarvis build Nightly + dsplayer support.
git:
https://github.com/mediaBrasil/xbmc/tree...r_dsplayer
Is there a working 16.1 RC1 link anywhere? Thinking of replacing MediaPortal clients with Kodi and want to try out MadVR support.
link for download:
Warnings:
git:
I think the latest is RC2, also linked in this thread.
Kodi Jarvis 16.1 RC2 + dsplayer * (03/28/2016)
link for download:
https://dl.dropboxusercontent.com/u/7799...0.dx11.exe
Update internal lav filters for version 0.68.0-16 (03/28/2016).
Warnings:
git:
MediaBrazil forum Website - Youtube Channel
Aeon MQ8 & Ace2-1.6.0 Skin Team
MarcosQui Website Donate and support us.
(2016-03-28, 21:56)Wanilton Wrote: Kodi Jarvis 16.1 RC2 + dsplayer * (03/28/2016)
link for download:
Warnings:
git:
Thanks again. I would suggest not updating LAV Filters again for Jarvis 16.1 final. It is better to stay with 0.68 stable rather than a nightly build, which may contain bugs.
@Warner306, for final version I will compile 2 releases, one with Lav update and other with version 0.68 stable.
Can any one tell me if this version of Kodi handles x265 hevc sources better than official kodi player? I have zotac zbox CI320 (cpu intel celeron N2930), and I experience video stuttering and out of sync audio, when trying to play video content 1080p coded with x265 HEVC codec. I am aware that my cpu and integrated graphic card is a little bit underpowered, but I did try with vlc player and it seems that it can play those videos ok.
You maybe fine with DSPlayer configured with Lentoid HEVC Decoder.
(2016-03-29, 13:38)oldpoem Wrote: You maybe fine with DSPlayer configured with Lentoid HEVC Decoder.
Thanks for the answer I will have to test this. One more is it ok to install this version on top of my official kodi build, will my userdata (like settings for skin) stayed the same?
(2016-03-29, 15:09)qzem Wrote: One more is it ok to install this version on top of my official kodi build, will my userdata (like settings for skin) stayed the same?
Settings and database are retained.
Thank you!
link for download:
Warnings:
git:
Many thanks.
Sapphire RX 5700 XT (19.9.2)  Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (1903), Silverstone LC13B-E, Onkyo TX-NR686, Samsung UE55KS8000, Mission M35i speakers, Kodi Dsplayer 17.6 X64
(2016-03-28, 22:39)Wanilton Wrote: @Warner306, for final version I will compile 2 releases, one with Lav update and other with version 0.68 stable.
Awesome. Glad to hear it.
Mac Mini (2.7GHz, Late 2012, Windows 10, Kodi DSPlayer) | SATV 16GB | Panasonic TX-P50GT50B | Yamaha RX-V675 | Q Acoustics 2010i (FL, FR, Left S, Right S), Q2000ci Center, Q2070si Sub
  • 213
  • 214
  • 215(current)
  • 216
  • 217
  • 501
  • 46 Vote(s) - 4.41 Average
Kodi DSPlayer – DirectShow Player for Windows4.4146
