2016-03-23, 02:59
I have an approx. 5 second delay before audio begins (video starts, audio is in sync once it begins) when using DSPlayer or MPC-HC. Is it possible to add a delay to the video portion to allow both to begin simultaneously?
(2016-03-23, 02:59)maddiesdad15 Wrote: I have an approx. 5 second delay before audio begins (video starts, audio is in sync once it begins) when using DSPlayer or MPC-HC. Is it possible to add a delay to the video portion to allow both to begin simultaneously?
(2016-03-22, 02:26)Warner306 Wrote:(2016-03-21, 21:52)brucethemoose Wrote: Does anyone else have problems with DVDs?
DSPlayer works fine with local videos off the hard drive as well as streams... but whenever I try to play a DVD with the latest DSPlayer build, it just uses the default Kodi renderer.
ISO support is lacking. DVD discs...I don't know. You might be better off using MPC-HC.
(2016-03-05, 03:00)Wanilton Wrote: Kodi Jarvis 16.1 RC1 + dsplayer * (03/04/2016)Is there a working 16.1 RC1 link anywhere? Thinking of replacing MediaPortal clients with Kodi and want to try out MadVR support.
link for download:
https://dl.dropboxusercontent.com/u/7799...5.dx11.exe
Update internal lav filters for version 0.67.0-142 (03/03/2016).
Warnings:
- This is an unofficial Kodi build not from Team Kodi.
- This build comes with no warranties, explicit or implied, and you use it at your own risk.
- This build was compiled by Wanilton, for use only in Windows OS, and have same functions official Kodi Jarvis build Nightly + dsplayer support.
git:
https://github.com/mediaBrasil/xbmc/tree...r_dsplayer
(2016-03-25, 20:58)DragonQ Wrote:(2016-03-05, 03:00)Wanilton Wrote: Kodi Jarvis 16.1 RC1 + dsplayer * (03/04/2016)Is there a working 16.1 RC1 link anywhere? Thinking of replacing MediaPortal clients with Kodi and want to try out MadVR support.
link for download:
Warnings:
git:
(2016-03-28, 21:56)Wanilton Wrote: Kodi Jarvis 16.1 RC2 + dsplayer * (03/28/2016)
link for download:
https://dl.dropboxusercontent.com/u/7799...0.dx11.exe
Update internal lav filters for version 0.68.0-16 (03/28/2016).
Warnings:
git:
link for download:
Warnings:
git:
