2015-08-23, 03:27
Latest release updated with build #0822b
(2015-08-23, 00:26)popcornmix Wrote:(2015-08-22, 21:25)polo_joe Wrote: What are the current hevc limits on rpi 2? resolution, bitrate
With these builds I think 1280x720 @ 1Mbit/s should always be safe.
Depending on encoding options 1280x720 at a few Mbit/s may work.
With overclock and the right encoding options you might get low bitrate 1080p.
(2015-08-21, 21:12)doveman2 Wrote:(2015-08-21, 17:21)L-S-D Wrote: aspect ratio information is present in SI tables of the TS and in the video sequence header of the encoded video stream, so maybe Kodi relies on the one and your STB on the other and ITV4 only sets one of them correctly?
It's my TV's built-in tuner I'm using, not a STB. If my TV (and I imagine 99% of other TVs, or else people would be rather unhappy) correctly detects 4:3 programmes and Kodi doesn't, I'd venture to suggest that Kodi is looking in the wrong place for the information (maybe technically one of the right places but not in the one that everyone else has agreed to use).
I've made a few short recordings of different channels and on none of them does Kodi detect 4:3 (or at least it doesn't switch the view mode to Normal, which is what I've set for 4:3). Even The Simpsons on Ch4+1 didn't this time, when I thought it did before but it was on Ch4 before, so maybe there's a difference between the two channels.
For the first two recordings I captured the transition between the adverts (16:9) and the programme (4:3) which on my TV auto-switches between the two modes but did nothing on Kodi. Touched by an Angel seems to be in some strange format, as on Normal it has black space above and below (this is with the TV in 4:3 mode) and I have to switch it to Original to expand vertically, which sets the Zoom to 1.09. When I play the other recordings, they all use Stretch 16:9 for both the adverts and the programme but when I play Touched by an Angel again it auto-changes back to Original, which I'm not sure how it's managing as the default is set to Stretch 16:9 and "Display 4:3 videos as" is set to Normal.
ITV3+1 - On the Buses: https://drive.google.com/file/d/0B1fDI89...sp=sharing
Ch4 - The Simpsons: https://drive.google.com/file/d/0B1fDI89...sp=sharing
True Entertainment - Touched by an Angel: https://drive.google.com/file/d/0B1fDI89...sp=sharing
Yesterday - Secrets of War: https://drive.google.com/file/d/0B1fDI89...sp=sharing
(2015-08-21, 06:19)illiac4 Wrote: In this sample file subtitles are shown on wrong side of the screen (left in the middle and not at the bottom) (you have to enable it if they are not shown). I know that in older versions it was playing fine but can not say when.
Using omx player.
File (size 13mb): http://bite-in.com/debug/24Kitchen-HD.ts
Using omx player.
(2015-08-23, 16:31)banesi Wrote: I didn't realised hevc encoding is problematic even for RP2 until I started watching a movie yesterday encoded in720p hevc, feels a bit dissapointed as I was under impression that it should have worked fluidly on this hardware.
I gotta say video qualty for a given size is just insane, hopefully things can get for a better in a future.
# uname -a
Linux rpi512 4.1.6 #1 Sun Aug 23 22:34:38 BST 2015 armv6l GNU/Linux
# vcgencmd version
Aug 23 2015 19:27:51
Copyright (c) 2012 Broadcom
version 41b1f861989dc4d1bbe19a52361a248ae57ee82b (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150823223350-#0823-gc06668c [Build #0823]
# vcdbg log msg 2>&1 | grep DTOK
001574.416: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
(2015-08-23, 14:43)afremont Wrote: I installed 0822b this morning. I put on live TV (mythpvr and HDHomerun) using DVDPlayer and I noticed the image didn't look as smooth as it should. I brought up the OSD and it looks to be skipping 10fps or so. The feed was 720p. I played a 720p recording and it did the same thing. I switched back to OMX and it looks fine. The OSD doesn't seem to show if it's skipping or dropping frames, but the video looks like it should.
I will do some more testing later with 1080i and SD TV channels to see if I can provide more information. I have to go right now though.
