2015-09-18, 00:17
(This post was last modified: 2015-09-18, 00:18 by shaunhoop1981.)
Hi great work on the official RPI touchscreen support
Can I ask if there will be further adjustments to how screen taps are processed
I am referring to latest build is smooth on the pointer to finger but selection requires double tap can this or will this be changed to one click selection to simulate android or ios touchscreen
Thanks again and I hope I'm not over stepping the mark by asking
2015-09-18, 00:43
(This post was last modified: 2015-09-18, 13:33 by hdmkv.)
Tested 3D ISO playback, works just as well as MVC MKV. Think I'll stick to latter though as smaller footprint and quicker playback.
Re: ISO's, chapter skips aren't enabled yet it appears? I only tried in 3D mode.
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
Periodically while watching recorded TV and skipping commercials, I'll skip too far forward and start skipping 10 seconds backward. After a few one or more skips backward, the video stops and freezes but the audio continues. I'll see this in the log:
20:15:11 84823.281250 T:1632084992 ERROR: CDVDMsgGeneralSynchronize - timeout
20:15:12 84824.187500 T:1632084992 ERROR: Previous line repeats 12 times.
The recorded TV is mpeg2 at 1080i60 and I'm using advanced deinterlacing.
2015-09-18, 06:45
(This post was last modified: 2015-09-18, 06:59 by dlxmax.)
I'm having a problem with video addons, starting with rpi2 build 907 (906 is great!).
When using a very popular video plugin, and this happens on at least one other popular plugin that I know of, and browsing though file lists, I've noticed that the display list is now forced to refresh every ~13 seconds. This results in being thrown back to the top of the list every 13 seconds--highly annoying when you're trying to figure out what to watch. Other times, if the refresh hits at some point during the processing of a file selected for play, I'll have to select "full screen" to get to the video right. And one time the refresh kicked me from one addon back to a previous one I'd been using.
I tested builds 917, 914, 911, 907, 906, 904, 901, and 823 in regards to this problem. The problem started with 907.
Thanks to all the devs, especially Milhouse, for your work. You've been rocking my 'box since 2002.
fixup_x.dat and start_x.elf and rename as last time or
fixup.dat and start.elf?
