Later tonight i will try 2D and 3D as you asked in an earlier post. One the iso's will be 300 rise of an empire.
I will use these settings:
- #1014
- 1080p/60
- 'sync playback to display'
- 'Support MVC video (full frame 3D)'
- 'Use Full HDMI modes for 3D'
Audio and the rest will be at default.
What to select for hardware acceleration? OMXPlayer or MMAL?
I am not on youtube as a poster so i won't be making a video like you did, but if you need some photos of my projector (for some feedback) than just state them.
hdmkv
Posting Freak
2015-10-16, 20:53
(This post was last modified: 2015-10-16, 20:53 by hdmkv.)
OMX disabled, rest of your settings are good. For audio, under Audio output, disable 'Enable passthrough' option, and set 'Number of channels' to 5.1 or 7.1 (whatever you have). I think there's a decode 8-channel option there that should be enabled.
hdmkv
Posting Freak
3D ISO stuttering worse for me (than what I demo'd in video on p.110) with build #1015.
Damn, seems like the RPi has fried another of my USB sticks. All the Windows tools I've tried to scan it just report the blocks are unreadable and can't reformat it.
This is the second stick that's died in my RPi's. The first had more use as I was using it for the /storage partition but this one I've barely used, as I only had it to record TV programmes onto and tvheadend isn't working for me most of the time. I haven't had any of my other sticks that I only use with PCs die, even though they're much older.
Oh well, I haven't got any need to use one with the RPi at the moment. If I ever get tvheadend working reliably, I'll have to look at recording to the SD card or a shared folder on my PC, although I'd rather avoid having to have the PC on when recording.
The Wetek splash screen is so much nicer, can we get a nicer one for the RP1/2 too?
