When i select OMXPlayer in video acceleration i have no sound.
And when i select both MML and OMX player is have sound.
i'm using a usb s/pdif.
For watching live tv streams with tvheadend and oscam wich one is better or is it better to use them both the same time?
noggin
Posting Freak
2015-10-31, 16:16
(This post was last modified: 2015-10-31, 16:17 by noggin.)
I have a feeling that OMXPlayer doesn't support USB sound output - only HDMI or internal analogue - as it uses the OMX framework?
OMXPlayer has often worked better for me than MMAL Player for DVB stuff - but I'm not sure how the priority works (I don't think you can use both at the same time as they do the same thing)
MONSTA
Senior Member
When selected both method, then OMX does video decoding. So no reason for worry.
All my 3D ISO's are playing in 2D mode with latest build... anyone else have this happening? I have 'Use Full HD HDMI modes for 3D' enabled.
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
Which was the last version you had that worked well for 3D? Thanks.
My HT
2015-11-01, 03:12
(This post was last modified: 2015-11-01, 03:57 by jompjomp.)
I've been trying out 3D on my pi2 and it's working great except for one Blu-ray 3D .iso. It has odd artifacting at specific, duplicatable times. If I make a 3D MVC mkv with makemkv it plays fine without artifacting. My theory is the seamless branching on the .iso is causing these problems. Is this a known issue?
I keep struggling to keep my mysql library working due to the many library version updates.
I just downloaded #1031 and also win and mac nightlies. I am not sure which OS is out of sync, but it looks like not all nightlies from today are using the same library version.
How are others working around to keep their library version in sync when using mysql and different OS at the same?
Server: Asus Sabertooth Z77 | Intel Core i5 3.4 GHz | 16 GB DDR3 | 128 GB SSD, 82 TB (9 x 6 TB, 7 x 4 TB)
HTPC 1: Raspberry Pi 2 | HTPC 2: Raspberry Pi 2 | HTPC 3: Raspberry Pi
Milhouse
Retired Team-Kodi Member
2015-11-01, 09:02
(This post was last modified: 2015-11-01, 09:35 by Milhouse.)
Kodi master nightlies (including #1031) should all have musicdb v56 and videodb v99 - what database versions do you have on Windows and Mac?
Edit: I had to delay the v55 to v56 musicdb bump for a few days between #1025 and #1030 due to conflicts with PR8285 and VideoPlayer, so it's entirely possible that musicdb on Win and Mac nightlies might have bumped ahead of my builds during this time, depending on when you updated the Win/Mac builds. Prior to that, musicdb bumped v54 to v55 in #1015 after PR8159 and would have been in sync with nightly builds for other platforms up until #1025.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
