  • 124
  • 125
  • 126(current)
  • 127
  • 128
  • 168
  Thread Closed
OpenELEC Testbuilds for RaspberryPi (Kodi 16.0)
(2015-11-01, 13:32)popcornmix Wrote:
(2015-11-01, 03:12)jompjomp Wrote: I've been trying out 3D on my pi2 and it's working great except for one Blu-ray 3D .iso. It has odd artifacting at specific, duplicatable times. If I make a 3D MVC mkv with makemkv it plays fine without artifacting. My theory is the seamless branching on the .iso is causing these problems. Is this a known issue?
So far not reproducible. I would be very interested in a sample file that shows the problem.
I can do that! How do I do that though? It's a ~30gb .iso, although the problem manifests itself right at the beginning. Is it possible to trim that file down?
(2015-11-01, 14:15)jompjomp Wrote: I can do that! How do I do that though? It's a ~30gb .iso, although the problem manifests itself right at the beginning. Is it possible to trim that file down?
It's a lot easier to trim the mkv than the iso. Are you on windows or linux?
In kodi, if you choose context menu on the iso file and then "browse into" and go to BDMV/STREAM/SSIF/ are there multiple .ssif files? Do any of the smaller ones have the playback problems?
I am using #1031 (Rpi2) and am having some playback issues, which I have not experienced before. I get occasional stutter and also occasionally audio disappears. Both is new with this built for me. A bit hard to reproduce as it only happens occasinoally and not at the same points / videos. Any idea how I can best help trouble-shoot or already known issue anyways?
(2015-11-01, 14:48)steve1977 Wrote: I am using #1031 (Rpi2) and am having some playback issues, which I have not experienced before. I get occasional stutter and also occasionally audio disappears. Both is new with this built for me. A bit hard to reproduce as it only happens occasinoally and not at the same points / videos. Any idea how I can best help trouble-shoot or already known issue anyways?
Are you sure that #1030 doesn't have this issue?
Never tried #1030. Not sure what is the latest one I have tried, but probably around two weeks ago?
Do I read your reply right that this is a known issue?
(2015-11-01, 15:04)steve1977 Wrote: Never tried #1030. Not sure what is the latest one I have tried, but probably around two weeks ago?
No it is not a known issue. As you said you had new issues with #1031 then the obvious question is which build introduced the problem.
If you can identify the first build with the problem, then we can look through the changes and hopefully pinpoint what caused it.
(2015-10-31, 23:06)Milhouse Wrote: Yes, confirmed. #1030 is not playing 3D ISO in 3D (not offered the playback mode menu), but #1029 is playing them normally, offering the menu with choices of "Preferred mode", Monoscopic / 2D" etc.
Ah - there were a couple of upstream (fernetmenta branch) changes that meant a commit I had wasn't required, and then was required. I'll add it back in.
Currently it is only the automatic detection of 3D in ISO that is broken. Using the filename tags should still work. Will be fixed for tonight's build.
I've found two 3D films that exibit this behavior. I don't think it's seamless related, since my other working .iso's have similar directory structures.
*Edit: I tried to send a PM with sample link but I don't have permission to.
(2015-11-01, 21:19)jompjomp Wrote: *Edit: I tried to send a PM with sample link but I don't have permission to.
Yes, you need a certain number of posts (maybe 10?) before PMing is allowed.
You can email me at popcornmix at gmail dot com.
New OpenELEC Jarvis build #1101: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.12 #1 Sun Nov 1 23:03:37 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov  1 2015 14:49:52
Copyright (c) 2012 Broadcom
version 8f1c8e72174c0415fd479c1c7be66b880fab3d79 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151101230245-#1101-g85a6965 [Build #1101]
# vcdbg log msg 2>&1 | grep DTOK
001708.211: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (85a6965e, changelog) and tip of XBMC master (4ebcc8db, changelog) with the following modifications: Build Highlights:
  1. Kodi 16.0 Beta 1
  2. New firmware
  3. Bump libbluray-0.9.0
  4. Remove skin backward compatibility (PR:8239) - could result in some third-party skin issues (contact your skin maintainer)
  5. Fix for 3D ISO playback
Build Details:
  1. Firmware (Nov 1):
    • firmware: rpi_display: fix backlight ratelimiting on STC rollover See: link
  2. OpenELEC:
    • kodi: add Bluray patches (59e38dd7)
    • libbluray: update to libbluray-0.9.0 (257e3941)
    • libnfs: add libnfs upstream patches (5a506f85)
    • kodi: disable pvrmanager.syncchannelgroups (4d23f2d4)
  3. XBMC:
    • Fix compile time error (PR:8326, 1 commit, 1 file changed)
    • FIX: don't show size for non-file items (PR:8304, 1 commit, 4 files changed)
    • Increase dir cache max to 50 (PR:8288, 1 commit, 1 file changed)
    • bump to 16.0 beta1 (PR:8325, 1 commit, 3 files changed)
    • remove skin backward compatibility (PR:8239, 1 commit, 1 file changed)
    • FIX: [droid] Media keys handling fixups (PR:8331, 1 commit, 3 files changed)
    • [python] demote pythons stdout to loglevel debug (PR:8316, 1 commit, 1 file changed)
  4. newclock5:
    • New commits in this build:
      • pthreads: use mutex protocol PTHREAD_PRIO_INHERIT (241670de)
      • paplayer: wait for eof if no crossfading or cue sheet (84cb6005)
      • [videoplayer] Use InputStream's filename for determining stereoscopic mode (36fead55)
      • Revert "[mmalrenderer] Wait for vsync before submitting to mmal when display sync is disabled" (e80684df)
      • Revert "[rbp] Refactor the vsync handle to support multiple callers" (a4678a87)
  5. Additional commits/pull requests/changes not yet merged upstream:
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
I can confirm this issue: Getting distrortion and "green blocks" on some 3D films (Avatar, Spiderman) when using ISOs. WIth ISOs converted to MKVs everythings playing fine. Did also try it with latest #1101 release. The distortion and "green blocks" always appear at the same positions.
(2015-11-02, 16:51)mule1 Wrote: I can confirm this issue: Getting distrortion and "green blocks" on some 3D films (Avatar, Spiderman) when using ISOs. WIth ISOs converted to MKVs everythings playing fine. Did also try it with latest #1101 release. The distortion and "green blocks" always appear at the same positions.
I now have a sample with artefacts (thanks jompjomp), so hopefully there will be a solution to this soon.
(2015-11-02, 17:08)popcornmix Wrote: I now have a sample with artefacts (thanks jompjomp), so hopefully there will be a solution to this soon.
Yeah, Avatar .iso does it here as well. Beauty and the Beast is on the list too. I'm trying to figure out what the commonality is with these discs.
Fingers crossed, thanks.
Hi Milhouse and PopCornMixi ;-)
I've her with the MTV.de-Addon some Buffering ( in german: Zwischenspeicher) problems with this new beta build #1101 on my RPi2.
Video is stuttering, 50% on the MTV list (top100 Video charts) is not playable.
I think the old problem is a "Déjà-vu" ?
Builds bevor no Probs.
THX
Harald
  • 124
  • 125
  • 126(current)
  • 127
  • 128
  • 168
  Thread Closed
  • 10 Vote(s) - 5 Average
OpenELEC Testbuilds for RaspberryPi (Kodi 16.0)510
