Like S3nox I seem to be sseing the exact same issue but I have RPI-2 with a HiFiBerry Digi+ (runnig over SPDIF to my amp).
Everything works on 6.0.0, but in both dev builds 1106 and 1107 I have the S3nox issue, clicking noises and the player runs the counter
at about x5 speed, and no sound from movies. ( I have not tried earlier ones).
see
http://xbmclogs.com/pne9xlx8e
I get lots of this in the log file:
15:41:21 14.908775 T:1963274240 NOTICE: Running database version Addons20
15:41:23 16.770435 T:1963274240 NOTICE: start dvd mediatype detection
15:41:23 16.822298 T:1963274240 WARNING: CSkinInfo: failed to load skin settings
15:41:24 17.909468 T:1963274240 WARNING: Previous line repeats 1 times.
15:41:24 17.909632 T:1963274240 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:41:24 18.032183 T:1963274240 NOTICE: ActiveAE DSP - starting
15:41:24 18.071171 T:1963274240 NOTICE: initialize done
15:41:24 18.071386 T:1963274240 NOTICE: Running the application...
15:41:25 18.572470 T:1963274240 NOTICE: starting zeroconf publishing
15:41:25 18.575850 T:1963274240 NOTICE: WebServer: Started the webserver
15:41:25 18.576258 T:1963274240 NOTICE: starting upnp client
15:41:25 18.593479 T:1636881312 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:41:25 18.593771 T:1636881312 NOTICE: UDP: Listening on port 9777
15:41:25 19.042219 T:1740632992 NOTICE: ## OpenELEC Addon ## 0.6.8
15:41:25 19.050814 T:1740632992 WARNING: CSkinInfo: failed to load skin settings
15:41:26 20.098246 T:1963274240 WARNING: Previous line repeats 1 times.
15:41:26 20.098425 T:1963274240 ERROR: Control 1500 in window 13001 has been asked to focus, but it can't
15:41:59 53.026920 T:1504760736 WARNING: CSkinInfo: failed to load skin settings
15:42:02 56.095501 T:1963274240 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
15:42:32 85.662323 T:1963274240 NOTICE: CDVDFactoryInputStream::CreateInputStream - <f1> /var/media/Media-USB1/TEST/test-1-mp3-320.mp3 <ssif>
15:42:49 102.591774 T:1963274240 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
15:42:52 106.255547 T:1636881312 NOTICE: ES: Client from 127.0.0.1 timed out
15:43:40 153.883499 T:1875899296 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
15:44:00 173.674927 T:1963274240 ERROR: Previous line repeats 14 times.
15:44:00 173.675095 T:1963274240 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
15:44:02 175.849640 T:1875899296 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
15:44:06 180.093369 T:1963274240 ERROR: Previous line repeats 4 times.
15:44:06 180.093552 T:1963274240 NOTICE: CDVDFactoryInputStream::CreateInputStream - <f1> /var/media/Media-USB1/TEST/test-1-mp3-320.mp3 <ssif>
The: "ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover" is the line sthat then keeps croping up.
Any thoughts?
