2015-11-09, 09:09
(2015-11-07, 15:25)Caramba69 Wrote:(2015-11-07, 12:35)mule1 Wrote:(2015-11-05, 21:24)mule1 Wrote: Is it usual that navigating (using skips) in a 3D movie using the latest testbuilds (started testing from build #1029) is yet nearly impossible?
In rare cases after a skip the movie continues to play. But most times Kodi only fills the buffer (shown in the GUI) but never continues to play the movie or the movie continues to play but only with 2-4 frames per second or if it continues there are heavy stutters. Stopping and trying to resume shows the same results. ISO seems to be even worse than MKV files. Navigating in non 3d movies is working as it should.
No one else having these issues? Is navigating (skipping forward, backward, fast forward, rewind) in 3d movies working flawless for you?
I will check this tomorrow as well. Perhaps also somebody else can check?
Skipping works for me.
