2015-11-12, 16:53
(This post was last modified: 2015-11-12, 16:57 by SofaKng.)
Thanks for the reply. I'm using MKV files ripped using MakeMKV so they are full-quality/bitrate Bluray rips.
I'll do some testing with iperf and see if I have nay problems. Thanks again!
EDIT: Oh, I almost forgot to mention but I have this little square in the upper-right with lots of colors in it that doesn't disappear? I just did a search and it looks like this is caused by under-voltage. I've ordered the official Pi power supply, but for now I'm using an Apple 10W (2.1A) PSU connected to a microUSB cable so that's strange to see the warning?
I'm not sure, but maybe a small step in the right direction.
When watching live tv with video codec info screen i have a lot of skip and errors when select deinterlace mode mmal advanced same with auto select mode.
I have half a screen of green and artifacts since the last update. This for every video i try to play.
2015-11-13, 02:16
(This post was last modified: 2015-11-13, 02:19 by albertstroh77.)
Just tried the 11-12 version and the hifiberry quit working. There was no option to choose it in the audio output. Tried the 11-10 version and it was working then. Had the option to choose pulse audio and it was working.
Edit: Sorry, not sure how the multiple posts happened.
fnc1
Senior Member
awesome work..
just installed 1112
but i was wondering if there is anything i can do to increase the speed when trying to watch a BR.iso.. on the rpi2 it takes 2-3 mins before i get the pop up asking which stream i want to watch. with a lot of these lines repeating. other boxes its maybe 10 seconds.
18:28:06 1275.958252 T:1543500816 DEBUG: CNFSFile::Open - opened export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1276.260010 T:1543500816 DEBUG: CNFSFile::Close closing file export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1276.265015 T:1543500816 DEBUG: CNFSFile::Open - opened export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1276.567505 T:1543500816 DEBUG: CNFSFile::Close closing file export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1276.572510 T:1543500816 DEBUG: CNFSFile::Open - opened export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1276.870361 T:1543500816 DEBUG: CNFSFile::Close closing file export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1276.875366 T:1543500816 DEBUG: CNFSFile::Open - opened export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1277.179810 T:1543500816 DEBUG: CNFSFile::Close closing file export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:07 1277.184937 T:1543500816 DEBUG: CNFSFile::Open - opened export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:08 1277.485596 T:1543500816 DEBUG: CNFSFile::Close closing file export/Media/Movies/Bluray_iso/2_Guns_2013.iso
18:28:08 1277.502197 T:1965367296 DEBUG: CDVDInputStreamBluray::Logger - bluray.c:1507: BLURAY destroyed!
Milhouse
Retired Team-Kodi Member
(Duplicate posts deleted)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
