2015-11-29, 10:07
(2015-11-29, 09:54)polo_joe Wrote: tvheadend working again! thanks much
Thank @gendo for the useful report.
(2015-11-29, 09:11)Milhouse Wrote:Switched from build #1127 to #1128 this morning and tvheadend client indicated that Tvheadened backend was lost(2015-11-29, 07:40)gendo Wrote: getting this error when starting tvheadend.
tvheadend: error while loading shared libraries: libssl.so.32: cannot open shared object file: No such file or directory
Use the latest #1128 tvheadend from the addons folder. The last #1128 build bumped libressl and now includes libssl.so.35 so any add-ons linking against a shared libssl will need to be updated.
(2015-11-29, 09:11)Milhouse Wrote:(2015-11-29, 07:40)gendo Wrote: getting this error when starting tvheadend.
(2015-11-29, 12:39)doveman2 Wrote: Can't seem to install the vdr #1128 zip with #1128.
(2015-11-26, 12:27)bagofcrap24 Wrote: 1125 does reboot reliably
#1124y Fail to reboot - http://pastebin.com/bTYTizSy
#1125 reboot works - http://pastebin.com/4dmwTz7N
OpenELEC:~ # openvpn /storage/.kodi/addons/network.openvpn/bin/openvpn/ovpn-open
elec/openelec.ovpn
openvpn: error while loading shared libraries: libssl.so.32: cannot open shared object file: No such file or directory
(2015-11-16, 13:58)popcornmix Wrote:(2015-11-16, 00:00)nalor Wrote: I'm trying to play encrypted iso files in 2D (this worked in the past without problems) and 3D if possible.
But just for interest I could really try to play discs also directly from optical drive
Is this currently working on OE 6.0? That does have libaacs.
Is it slower to start playback of encrypted ISOs?
Logically it would make more sense to remove the encryption when ripping the ISO rather than trying to remove it every time you play the ISO (potentially needing decryption support on multiple devices).
I would be interested if you can play straight from an optical BlueRay drive (either locally attached or from a network share). Don't think I've heard of that working (except from a network share from a PC running anydvd or similar to remove the encryption).
(2015-11-29, 23:28)nalor Wrote: Can you tell what kind of problems appeared with libaacs? I couldn't find anything here in this thread nor in the RaspberryPi section here in the forum - I only noticed that libaacs got removed beginning with build #1010 and the comment 'disable libaacs as this seems to be responsible for BD ISO crashes' - but couldn't find details about this issue.
(2015-11-29, 23:28)nalor Wrote: Is it possible to active libaacs in recent builds? Or has it to be activated already during compilation? Would it be possible to create eventually a single build with enabled libaacs? Thanks!
# uname -a
Linux rpi512 4.3.0 #1 Sun Nov 29 21:35:26 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 25 2015 17:54:26
Copyright (c) 2012 Broadcom
version fda23007cfd89bf42af864b57701b39e1ac8c552 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151129213436-#1129-gc5875ae [Build #1129]
# vcdbg log msg 2>&1 | grep DTOK
001707.922: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
