  • 158
  • 159
  • 160(current)
  • 161
  • 162
  • 168
  Thread Closed
OpenELEC Testbuilds for RaspberryPi (Kodi 16.0)
(2015-12-03, 18:13)popcornmix Wrote:
(2015-12-02, 23:55)Milhouse Wrote: [*][input] Add some logging for input device (54c1f25c)
@jackiass - can you update to latest version (which will still have the multitouch issue) and post a debug log?
I've added some logging that shows all the features your keyboard reports. I suspect it is reporting something multitouch related which causes the conflict.
I'll get right on it after work!
Hi, like other users who were having lib issues a couple of builds ago, I am unable to run the transmission package.
The transmission daemon fails to load:
transmission-daemon: error while loading shared libraries: libcrypto.so.32: cannot open shared object file: No such file or directory.
I can't see that either the daemon or the interface program have changed recently, so I assume it must be a change in the kodi build.
Could you please take a look?
I have uploaded new transmission addons in the addons folder.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2015-12-04, 15:26)Milhouse Wrote: I have uploaded new transmission addons in the addons folder.
That's awesome, thank you, but still the same problem.
I have uninstalled the originals script interface and daemon, removed the cached packages and refreshed the addon libraries but get the same results.
Am I downloading from the right area?
I installed the transmission script v0.76 from Program-Add-On's from the kodi add-on repository
and the transmission service 6.0.0 from Unofficial Openelec add-on repository.
Edit: I think I need to download from here :
http://milhouse.openelec.tv/builds/addon...nsmission/
http://pastebin.com/ZxTLgSZ5
Here is the full log. I installed the latest build 1203. The log is how it looks after a restart and then me using the right button once. The highlight disappeared right after that.
Right here:
13:54:27  44.262341 T:1964769280   DEBUG: OnKey: right (0xf083) pressed, action is Right
13:54:27  44.263119 T:1638646688   DEBUG: Thread Timer start, auto delete: false
13:54:27  44.451435 T:1762014112   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-arm.so)
13:54:27  44.451897 T:1762014112   DEBUG: Loading: /usr/lib/kodi/system/ImageLib-arm.so
13:54:28  45.265602 T:1638646688   DEBUG: Thread Timer 1638646688 terminating
(2015-12-04, 15:54)b1m1 Wrote: Edit: I think I need to download from here :
Yes...
Yes...
Downloaded, installed and running. Thank you so much for your help.
Navigating the add-ons from the PROGRAMS menu is always wonky i.e I always have to go in-and-out back-and-forth until the right menu options come up
... has it always been that way?
Thanks again.
(2015-12-04, 16:17)b1m1 Wrote: Navigating the add-ons from the PROGRAMS menu is always wonky i.e I always have to go in-and-out back-and-forth until the right menu options come up
Thanks again.
No idea, not even sure I understand the issue. When did it become a problem - can you identify the first build that exhibits the problem, and perhaps explain it in more detail (screenshots often help).
(2015-12-04, 15:59)jackiass Wrote: Here is the full log. I installed the latest build 1203. The log is how it looks after a restart and then me using the right button once. The highlight disappeared right after that.
Thanks. I've reported to original author and he's commented: https://github.com/xbmc/xbmc/pull/8129#i...-161988960
OpenELEC doesn't have evtest. Can you connect the keyboard to a linux machine (Pi running raspbian should be suitable) and run:
evtest /dev/input/event0
and press some keys (or trigger other bits of keyboard if it has touchpad or similar).
Repeat for event1, event2, event3. @maxnet would like to know how the keyboard uses each of the four reported interfaces.
You may need to run "sudo apt-get install evtest" first if it is not installed.
Another update. Running live TV test for 2.5 hours so far this morning (same 720p channel as before), no issues. Only difference is that I enabled Adjust Refresh Rate. I don't use that in the living room because it causes black screens for a few seconds with Onkyo TX-NR828 AVR and Optoma HD-25e projector while everything readjusts itself. Maybe this is the culprit? I'll continue to let the live TV play out and update if it starts skipping frames. So far though, everything looks and sounds good. I thought it odd that the TV switched to 1080i mode even though the source is 720p. CPU usage is much less than it was before turning on the adjust refresh rate option. That seems to make sense since it only has to generate half as many frames as it did with the display in 1080p mode.
Here is the log in case it matters:
http://sprunge.us/TAdQ
(2015-12-04, 18:05)afremont Wrote: Here is the log in case it matters:
Would be more useful if debug was enabled...
After I give this test (with adjust refresh rate enabled) another hour or two to see if the problem occurs, I'll disable the adjust refresh rate and capture a debug enabled log for which I know (pretty much 100% confidence) that the problem will occur. I'd first like to see if adjust refresh rate has anything to do with it. zaphod24 has a very similar setup to mine, yet he never experiences the issues. One of the differences in our setups is him having adjust refresh rate enabled. There are other subtle differences, but this one may be the key to this, especially since I've had my test running for three hours with no issue. That is significant in my experience.
EDIT: BTW, so far I'm having good results running OE6 on the living room setup with OMXPlayer disabled. That has been running for 5 hours straight on the same channel as the bedroom setup. I do not have adjust refresh rate enabled in the living room. I think we're getting somewhere now.
Update, just before reaching the four hour point, it suddenly stopped playback and went back to the main screen. The myth backend messages indicate that the Pi asked to close the stream. This message appeared at the end of dmesg output on the Pi:
[14220.056732] vchiq: 0: ignoring ERROR from callback to service d00c
I don't know what that means exactly, but it appears to have caused OE to stop playback. Everything looked fine until that point. Still almost 4 hours of good playback is something that I haven't seen in a long time. I'm really beginning to think that adjust refresh rate being disabled has something to do with the problems I experience. I'm going to disable refresh rate change, turn on debugging and reboot. Then I will start a live TV playback and stop it when/if problems occur. I will then post the entire log thru pastebinit.
EDIT: As for the 1080i thing, it appears that OE wants to drive that display in that mode all the time for some reason, not just after starting playback. Adjust refresh rate doesn't seem to be the cause of that. I enabled debug logging, turned of adjust refresh rate and rebooted. I'm experiencing audio stutters right off the bat but so far the video looks like it should.
hi,
is there any option to play in future a DVD over the included Menue (video_ts.ifo) ?
Thanks for your hard work.
New OpenELEC Jarvis build #1204: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.0 #1 Fri Dec 4 21:02:55 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 30 2015 20:58:50
Copyright (c) 2012 Broadcom
version 411fa8fd4bbe6a0a4b0c50f09330ce84c1d70b3d (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151204210207-#1204-gc5875ae [Build #1204]
# vcdbg log msg 2>&1 | grep DTOK
001692.542: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (c5875ae6, changelog) and tip of XBMC master (a01bb2af, changelog) with the following modifications: Build Highlights:
  1. Build: Switch kernel branch from rpi-4.3.y_rebase to rpi-4.3.y
Build Details:
  1. XBMC:
    • [events] fix removal of events (fixes #16403) (PR:8463, 1 commit, 1 file changed)
    • Set the XBox 360 X button action to ContextMenu in an addon (PR:8448, 1 commit, 1 file changed)
    • [music] Listeners should not be able to hold a negative value (PR:8442, 1 commit, 1 file changed)
    • [Confluence] - fix navigation for SideBar NowPlaying controls (PR:8471, 1 commit, 1 file changed)
    • [cmake] fix package-addon (zip) target on linux (PR:8475, 1 commit, 2 files changed)
  2. newclock5:
    • New commits in this build:
      • ActiveAEStream: Avoid memcpy but take care for byte access (c6f1c620)
      • Merge pull request #334 from fritsch/truehd (71378b96)
      • [videoplayer] Use a copy of stream info for thread safety (eb6af4c5)
      • Merge pull request #333 from popcornmix/playerlock (7054ab95)
      • CBaseTexture: Removed parameter for SetMipmapping (4445261b)
      • High quality downscaling moved to the slideshow category (rendering category axed) (2b624aec)
      • CSlideShowPic: moved mipmapping activation from UI code to proper location (e24acc47)
    • Commits no longer in build:
      • [dvdplayer] Add lock for player creation (d662b56d)
  3. kernel 4.3.y:
      • BCM2708: Use upstream interrupt driver on all Pi1's (4a57b61b)
      • BCM270x: Switch to firmware driver (a2416c9a)
      • BCM2708: Use brcm,bcm2835-system-timer (de957bb0)
      • mailbox: bcm2835: Support ARCH_BCM270x (e7a8a95c)
      • Add bcm2708_gpio driver (1ebd175f)
      • bcm2708 watchdog driver (5f7a83bf)
      • bcm2835-audio: Create the platform device if the DT node is disabled (3a999971)
      • Add hwrng (hardware random number generator) driver (3ba7b24a)
      • Add Chris Boot's spi driver. (69105999)
      • ASoC: Add support for BCM2708 (573ddddc)
      • BCM2708: Add I2S support to board file (caa36c0f)
      • BCM2708: Added support for HiFiBerry Digi board Board initalization by I2C (9fe685e4)
      • Added support to reserve/enable a GPIO pin to be used from pps-gpio module (LinuxPPS). Enable PPS modules in default config for RPi. (86e63a0b)
      • bcm2709: Simplify and strip down IRQ handler (892ad15a)
      • mach-bcm270x: Enable the building of pinctrl-bcm2835 (472e1a31)
      • BCM270X_DT: Add pwm and pwm-2chan overlays (3ba398f9)
      • lirc-rpi: Make buildable on bcm2835 (0f1e587e)
      • i2c-bcm2708: Make buildable on bcm2835 (9f2b30f4)
      • bcm2708-i2s: Make buildable on bcm2835 (f5a639a7)
      • vchiq: hack: Add include depecated dma include file (2d840791)
      • bcm2709: Remove custom barrier implementation it is no different to default (95547b46)
      • dwc_otg: Remove duplicate gadget probe/unregister function (dd834a28)
      • config: remove CONFIG_CPU_SW_DOMAIN_PAN it causes panics (83c7a839)
      • BCM270X_DT: configure I2S DMA channels (d8ea31d6)
      • configs: enable SND_BCM2835_SOC_I2S (d88a42c2)
      • BCM270X_DT: switch to bcm2835-i2s (244eb406)
      • config: fix RaspiDAC Rev.3x dependencies (bd4c88f2)
      • bcm2708-i2s: Remove driver (39fee189)
      • dmaengine: bcm2708: Make legacy API available for bcm2835-dma (58c46cd9)
      • configs: Enable DMA_BCM2835 (e26d3431)
      • dmaengine: bcm2708: Change DT compatible string (b8313464)
      • dmaengine: bcm2708: Remove driver but keep legacy API (91aeeb42)
      • bcm2835-gpiomem: Fix for ARCH_BCM2835 builds (a849e5ca)
      • BCM2835-V4L2: Return buffers to videobuf2 on shutdown (3ee0d9c9)
      • BCM270X_DT: Enable the watchdog (8822596a)
      • scripts: Multi-platform support for mkknlimg and knlinfo (4781f953)
      • bcm2708_wdog: Remove driver (bd8a3960)
      • bcm2708-rng: Remove driver (38608d47)
      • spi-bcm2708: Remove driver (ccd99eb9)
      • BCM270X_DT: Remove spi controller overlays (53643de2)
      • i2c-bcm2708: Remove non-DT support (b6581a5c)
      • lirc_rpi: Remove non-DT support (3cbaa5b1)
      • vc_cma: Provide empty functions when module is not built (2357a22b)
      • vc-sm: Move headers out of arch directory (eddd1a86)
      • bcm2708: Remove unused headers (47f78e56)
      • bcm2708: Remove bcm2708_gpio (f3feb3fe)
      • bcm2708: Disable ATAGS (737ad138)
      • dwc_otg: Simplify FIQ irq number code (836b1618)
      • bcm2708: Remove armctrl irq driver (3e4f56b8)
      • bcm2709: Make early printk possible on uart0 (98f8b7cf)
      • bcm2709: Remove unnecessary files (e1fa6324)
      • bcm2709: Remove bcm2708_gpio (082380ee)
      • bcm2709: Disable ATAGS (c6b2326f)
      • clocksource: arm_arch_timer: Remove dc4_arch_timer_init() (c01324c1)
      • serial/amba-pl011: Remove fifo size hack (1cd44cc1)
      • Merge pull request #1178 from notro/multi2708 (ad3300ed)
      • config: Add CONFIG_UHID (6163e954)
      • Add support for the HiFiBerry DAC+ Pro. (6293d5b8)
      • config: Add CONFIG_CRYPTO_USER_API_SKCIPHER (a63dbb6f)
      • config: Add options for supporting openlabs 802.15.4 radio (8f61dab7)
      • BCM270X_DT: Add at86rf233 overlay (baf20898)
      • BCM270X_DT: Make mmc overlay compatible with current firmware (9734c512)
      • bcm2708: Use #include in dtsi files. (a51e1e08)
      • clk: bcm2835: Move under bcm/ with other Broadcom SoC clk drivers. (c016b19a)
      • clk: bcm2835: Add binding docs for the new platform clock driver. (7a0dbbbe)
      • clk: bcm2835: Add support for programming the audio domain clocks (422afe29)
      • clk: bcm2835: Also build the driver for downstream kernels. (6aa11258)
      • bcm2835: Add (disabled) devicetree for the audio clock manager. (0392bc4f)
      • drm/vc4: Add devicetree bindings for VC4. (05a40f07)
      • drm/vc4: Add KMS support for Raspberry Pi. (e449268e)
      • drm/vc4: Use the fbdev_cma helpers (2a5db764)
      • drm/vc4: Allow vblank to be disabled (1adf08ec)
      • mm: Remove the PFN busy warning (9ff049ed)
      • drm: Put an optional field in the driver struct for GEM obj struct size. (069b10bc)
      • drm/vc4: Add suport for 3D rendering using the V3D engine. (47bde3a1)
      • drm/vc4: Force HDMI to connected. (8f3c2c81)
      • drm/vc4: bo cache locking fixes. (981be2e7)
      • drm/vc4: bo cache locking cleanup. (f1891cf7)
      • drm/vc4: Use job_lock to protect seqno_cb_list. (8d3b50d7)
      • drm/vc4: Drop struct_mutex around CL validation. (1ca09aad)
      • Add vc4-kms-v3d overlay (0a41cf38)
      • drm/vc4: Enable VC4 modules, and increase CMA size with overlay (e62f3a46)
      • drm/vc4: Increase CMA size to 256M aligned to 256M boundary (a0f89929)
      • config: Add FB_TFT_ILI9163 module (bcbf3a33)
      • drm/vc4: Drop struct_mutex around CL validation. (96f1219f)
      • drm/vc4: Add support for more display plane formats. (b1a5eb34)
      • drm/vc4: No need to stop the stopped threads. (d0439373)
      • drm/vc4: Remove extra barrier()s aroudn CTnCA/CTnEA setup. (85b59fef)
      • drm/vc4: Fix a typo in a V3D debug register. (014d2550)
      • New overlay for PiScreen2r (a0a66402)
      • Input: add support for FocalTech FT6236 touchscreen controller (23a72384)
      • Input: ft6236 - do not explicitly set driver's owner (0aeb2493)
      • Input: ft6236 - change module license string to match copyright notice (342b617e)
      • config: Add TOUCHSCREEN_FT6236 (2a7da741)
      • Build i2c_gpio module and add a device tree overlay to configure it. (9103a69a)
      • config: Add MCP320X (8b65b4ba)
      • dts: Added overlay for Adafruit PiTFT 2.8" capacitive touch screen (b98336e0)
      • rpi-ft5406: Use interruptible sleep to avoid high load reported (62a2588f)
      • config: ADD CONFIG_FB_UDL module (USB displaylink) (e475b3c2)
      • bcm2709_fb: refine appropriate behaviors to unsupported fb ioctls (addc6d03)
      • dts: Added overlay for gpio_ir_recv driver (c3c084d6)
      • BCM270X_DT: Fix overlay README anomalies (b265f3f3)
      • SDIO-overlay: add poll_once-boolean parameter (50fb5daf)
      • BCM270X_DT: Use clk_core for I2C interfaces (917cbb64)
      • lirc-rpi: FIXUP correct error code (should be negative) (40425cf8)
      • FIXUP BCM270X_DT: Use clk_core for I2C interfaces (113ae4b0)
      • Revert "bcm2708: Allow option card devices to be configured via DT" (ac0f3d66)
      • squash: include ARCH_BCM2708 / ARCH_BCM2709 (22401464)
  • 158
  • 159
  • 160(current)
  • 161
  • 162
  • 168
  Thread Closed
  • 10 Vote(s) - 5 Average
OpenELEC Testbuilds for RaspberryPi (Kodi 16.0)510
