Milhouse
Retired Team-Kodi Member
It certainly worked at the time, so should work now. Work is progressing towards an official OpenELEC 7.0 Jarvis release
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Do you know if there are any blocking points/issues this time like there were with 6.0.0, or is it just a case of it's taking a little time to get everything done and right and patience needed?
Milhouse
There are some blockers, yes. One of them being a Python issues that has hopefully been resolved today.
I am having issues pairing my device (rpi2) with the 1204 build - this is the first time I am trying this so I am not sure what the issues are - my bluetooth adapter is an ASUS adapter (BCM20702A0 Broadcom based). I can detect my headphones (ankerSoundbuds) - but when I pair them, it says connected for a few seconds then says file "Bluetooth Error - no such file or directory".
Not sure what to do here - any help would be great.
Can anyone recommend a reputable source to get a current build of OE7 ? This seems to be oddly lacking to my searching.
Milhouse
Yes. Just drop the 6.0.1 tar file in the Update folder and reboot.
I'm running my own compiled build from the master git on Kodi 16.0 (Jarvis) is there a way to upgrade this to the Kodi 16.1 RC1 version?
