2015-07-08, 15:34
Hi, hopefully you can help. At moment I'm on Milhouse 701 on my Raspi 2.
Scraping and cleaning up works fine except I have a lot of messages after cleaning with:
12:00:25 68181.593750 T:1967669248 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/play/?video_id=.........
I had the idea to remove it directly via MiniSQLquery but then I saw that under "files" in my DB there are many files which I no longer have in library.
Is there a way to clean them up with Kodi directly instead of SQL to be sure to get all not available files, maybe another cleanup add on?
Movies and series are ok, there is only the stuff in files and path which is no longer on my disc and I don't want to recreate whole library.
http://codeviewer.org/view/code:5324
