Hey Damac,
I will look into the add-on issues, thanks.
As for the custom items- all the home menu items are fully customizable. You can change all the names, functions, etc.
Hi mate, props on this skin. top work indeed.. one bug i have come accross is when trying to edit the home screen, the favourites option in the (custom tile) doesnt work properly, it allows u to select favourites but when u go to set the path (choose the fav) i get nothing.. nothing at all happens mate
Hey mate looks like a unreal skin!
Keen to give it a whirl but I am getting add-on dependencies as mentioned above ... with the 1.0.0. of the dependency files like studio images.
Was there a fix? I can't get the skin installed and tried manually installing all the dependencies and from offical kodi repo
Is there a way to have custom panels? The built in ones aren't loading
Hey man.... just wanted to say this skin has the potential to be incredible in my eyes
pretty buggy at the moment but gave it a spin for a couple days and really was impressed
hope you keep working at it!
