Im trying to add some music folders with Ogg Opus files on them, they are properly tagged, (i can see the correct tag info on foobar 2000 and MP3Tag), when i try to import new audio content in kodi it just doesnt read the tag because nothing was added to the music library its just like those files dont exist, when i try to play an opus file from that folder but now going directly to them it plays without a problem but if i choose to see file info no tag is displayed, that same file tag info displays ok in other software, maybe isengard 15 isnt compatible with Ogg Opus file tag info yet?
Please, does anybody knows if kodi isengard is able to read vorbiscomment tags from Ogg Opus audio files...i can't add my audio collection to music library because no information is read from my opus music files
Waiting for an expert to come along instead of me.....
Isenguard definitely handles vorbis comments from FLAC files. Kodi uses file extensions to determine what kind of tags to process, so how are these Opus files named? Are they .ogg?
2015-08-10, 08:28
(This post was last modified: 2015-08-10, 08:28 by Martijn.)
if the taglib we use could could handle it could possible just a simple one yes.
2015-08-10, 17:34
(This post was last modified: 2015-08-10, 18:16 by DigiTech.)
thanks fritsch but sorry for my novice knowledge, how can i add or build the latest libtag master branch to Kodi Isengard 15.0 latest official release, sorry again for my lack of habilities to do what you ask
any hope that this can be fixed by a patch or in future kodi versions...
fritsch
Team-Kodi Developer
No, sorry. When a new libtag version is out - we will take that. For now only bugfixes.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
2015-11-29, 21:00
(This post was last modified: 2015-11-29, 21:00 by Boulder.)
Did the commit make it to Kodi 16?
I built Kodi 16.0 (beta) using the last version of LibTag (1.10) but is still not possible to read opus tag. Seems is not enough to use the last version of libtag, maybe also some patch on the Kodi code is required?
Do you have any plan?
Ok, thanks for your answer. I will open a new thread on request forum. Unfortunately I'm not a good programmer, otherwise I would given my support.
