2015-10-19, 22:34
(This post was last modified: 2015-10-19, 22:46 by User 224999.)
(2015-10-19, 21:43)Tgxcorporation Wrote: (2015-10-19, 19:47)marcelveldt Wrote: OK, It's now added on Git. Please have a look at the readme how it works. You can use the webservice to do this.
Thanks, perfect!
Is it possible to make it work in MusicPlayer/MusicVisualisation screen too?
Thank you very much!
Tgx
Should work, I think you can use player.dbid for that, if not I will make sure that the window props will also be filled in the music player.
EDIT: Hmm MusicPlayer.DBID is not available as it looks like. I will extend the code to also fill the window props for the player tomorrow.
(2015-10-19, 22:13)tomer953 Wrote: http://pastebin.com/rQ3sQTEn
OK, not sure if this is going to fix it but please try latest Git.
im85288
Skilled Python Coder
Hi Marcel.
The wall views are working well, will you be adding TV Show support to it?
Possibly an option for a collage view aka Emby may look good to.
Thanks, perfect!
Tgx
Now added... See the readme because I've added a few additional properties that you can use in the player.
Also nice to know is that the script now also provides extrafanart for both music and pvr artwork.
(2015-10-20, 18:07)im85288 Wrote: Hi Marcel.
TVshows wall has been added. What do you mean with a collage view?
Jayz2K
Skilled Skinner
Stupid question Marcel ... but How do you get into the script settings. I'm trying the common way by the addons browser but your script isn't in the list ? Did I miss something ?
[Skin] KOver - V1.1.0 Stable (Repo version)
[WIP] ReKOver - Skinning tool project
If I've been helpful or you like my work, hit "THANK USER" button ;) ...
It is under "Add-ons" - "system" - "Running"
@marcelveldt love this project, keep up the great work...
(2015-10-22, 22:25)Lunatixz Wrote: Can you add looking up similar movies to a specific film?
ex:
plugin://script.skin.helper.service/?action=similarmovies&imdbid=tt0796366&limit=25
done, now on Git.
