(2015-10-26, 17:03)marcelveldt Wrote: (2015-10-26, 16:36)Dumyat Wrote: So I upgraded to the latest github and can now add new/overwright existing images ok, but I am seeing some other odd behaviour since upgrading. Everytime I open Kodi and go to the pvr epg, I don't get any artwork showing. However, if I go to addons, open the configure screen on your script and press okay, then go back to the pvr epg, all the artwork is showing immediately.
It might be (but I haven't tested it) that it will only start working when you browse the epg. Did you try to move to the next title to see if it pulls the artwork ? If not, please look in your kodi logfile, might be some clue in there...
(2015-10-26, 16:36)Dumyat Wrote: Also, I'm not getting poster artwork showing up for every programme that has been downloaded when using it with the DialogFullScreenInfo.xml file. What's strange is I get poster artwork for some shows, but not for others for some reason. This is the code, I'm using, which worked fine on the previous version of your script that I was using:-
PHP Code:
<texture fallback="new_pvr/blue/fallback/fallback_tvposter.png">http://localhost:8888/getthumb&title=$INFO[VideoPlayer.Title]&channel=$INFO[VideoPlayer.Channel]&type=poster</texture>
Is there anything I need to change on this code?
Please change the port to 52307, so localhost:52307 instead of localhost:8888. I had to change the port to something that really shouldn't be in use on the system.
Yeah, I tried next title, but no difference. In fact, I moved down the epg completely, but still not showing anything until I go to your script settings and then back to the epg. I did wonder if might have something to do with me not having the creation of wall/grid backgrounds enabled, as there is no requirement for me to use this feature? I know when I had that option initially enabled I wouldn't get any artwork showing in the epg, full-stop, even when I went to your addon settings screen and then back to the epg, but I will check the logfile and see if anything immediately shows up.....
Thanks, I add localhost:52307 to code, but still didn't work at first. But then I read something the other day, which I think you might have missed as I change the bit that says 'getthumb' to 'getpvrthumb' and all is working again now from what I tested so far.....
Thanks for your help
Edit: Same behaviour is happening when artwork is working in epg, but then I come out of that screen, go to another section like movie/tv show library for instance, then return to epg, no artwork shows up again, unless I go to your script settings screen.....
