marcelveldt, if possible please add support for 3 more items in Sets
Window(Home).Property(SkinHelper.MovieSet.X.Year)
Window(Home).Property(SkinHelper.MovieSet.X.Plot)
Window(Home).Property(SkinHelper.MovieSet.X.DBID)
Thanks,
Hello,
I use the Madnox skin with Kodi Jarvis on Windows 8.1 x64. I've noticed that Skin Helper Service is now showing up in my Music Add-ons section. It's strange to see that with all of the Internet Radio add-ons. Is there an option to prevent Skin Helper Service from showing up there or does this have to do with Madnox somehow?
Using the Eminence mod skin the duration of the video does not show up at all using version 1.0.68. Everything works perfectly using version 1.0.51 however. This is a problem for everyone using the skin.
loggio
Posting Freak
Hi marcelveldt,
The skin.helper service seems to download multiple images for any given show in the pvr section which is great. That part works.
Trying to change an image manually by selecting "artwork settings, refresh artwork (manually)" will not work if the skin.helper service has already got data for that particular program stored in the addon_data pvrthumbs folder.
If you want to use the refresh artwork (Manual) option you have to delete the folder for that program from the addon data folder first, then refresh it.
Cheers,
Loggio.
I would like to make a request. Since Kodi 15 it is possible to tag videos in Kodi. I use this to tag the movies with an atmos or auro flag. In the skin i show the audio flag if the movie is tagged with atmos or auro.
In my local copy of the skin helper service i have added a Tags property which reads all tags from a movie if present. If the movie is tagged with more tags like atmos and 3d the result property string is 'atmos,3d'.
I'm not the best python developer so it's a hacky way but it' works.
Maybe you could add this the correct way or if you like i can get you the code i use. Every time i update the skin helper service from git i have to add the modifications manually. So it would be nice if you could add
the Tags property.
