Hello.
I was looking into this addon as a replacement for script.videolanguage, but I have a couple of problems:
I don't seem to get SkinHelper.ListItemLanguages property set for musicvideos
I don't seem to get SkinHelper.ListItemLanguages or ListItemSubtitles properties set in videoplaylist, only videos.
Is that the way it is supposed to work?
scott s.
Hello Marcel,
How to enable pvr artwork in skin?
I'm using aeon nox SILVO mod but it says PVR THUMBS ARE DISABLED OR NOT SUPPORTED IN THIS SKIN.
Is there another workaround to enable pvr artwork?
(2016-06-04, 10:50)Mike_Doc Wrote: Seem the new albumsartist isn't working I tried
$INFO[Window(Home).Property(SkinHelper.Music.AlbumsArtist)]
$INFO[Window(Home).Property(SkinHelper.Music.albumscompilations)]
Did you flush the cache before trying ?
2016-06-06, 22:10
(This post was last modified: 2016-06-07, 08:37 by VikkiXavier.)
@Marcelveldt: Sir, can you please tell me how to get the number of critic reviews from metacritic.com? Like for e.g. X-Men: Apocalypse has been rated by 48 critics. How to get this number '48'?
Extended info on any user set widget.
I've got menu items for trakt tv shows, movies and also have my favourite video addon tv networks set on 4 widgets
It would be great to have extended info accessible from the video thumbnails on the home screen rather going into another screen.
In extended info default lists there is a user created lists section, if a workaround was to put our lists in there and use that as a widget can there be a context menu mod where you can add an entire list of shows rather than just one at a time.
Meaning go into video addon, ,networks, AMC "bring up context menu - add to list (user created list)
Can anyone help me out in achieving this?
I hope i explained it well enough.
myrasp
Junior Member
@marcelveldt
Artwork search for PVR:
It would be possible to place the search of sporting events in the EPG by the website thesportsdb.com , and for this purpose use the module " script.module.thesportsdb " , from the user enen92 .
It is a suggestion.
Thank you.
