2015-09-01, 18:59
I'm on Debian Sid. Trying to compile tvheadend and I have some troubles. First issue is abut libhdhomerun:
So it seems you are using some function not available in libhdhomerun1 20150826-1. After downgrading it to 20140604-2 everything is fine.
I don't need hdhomerun though, so I don't care. So I decided to disable it, but there is another problem (libsdl) that I can not handle:
Obviously, libsdl and libsdl-dev are installed:
What's wrong?
src/input/mpegts/tvhdhomerun/tvhdhomerun.c: In function ‘tvhdhomerun_device_discovery’:
src/input/mpegts/tvhdhomerun/tvhdhomerun.c:346:20: error: implicit declaration of function ‘hdhomerun_discover_find_devices_custom’ [-Werror=implicit-function-declaration]
int numDevices = hdhomerun_discover_find_devices_custom(0,
cc1: all warnings being treated as errors
Makefile:524: polecenia dla obiektu '/home/michal/tvheadend_src/tvheadend-master/build.linux/src/input/mpegts/tvhdhomerun/tvhdhomerun.o' nie powiodły się
make: *** [/home/michal/tvheadend_src/tvheadend-master/build.linux/src/input/mpegts/tvhdhomerun/tvhdhomerun.o] Błąd 1
/usr/bin/ld: cannot find -lSDL
collect2: error: ld returned 1 exit status
Makefile:520: polecenia dla obiektu '/home/michal/tvheadend_src/tvheadend-master/build.linux/tvheadend' nie powiodły się
make: *** [/home/michal/tvheadend_src/tvheadend-master/build.linux/tvheadend] Błąd 1
root@x-4e135accf5b64:/home/michal# dpkg -l | grep libsdl
ii libsdl-image1.2:amd64 1.2.12-5+b5 amd64 Image loading library for Simple DirectMedia Layer 1.2, libraries
ii libsdl-mixer1.2:amd64 1.2.12-11+b1 amd64 Mixer library for Simple DirectMedia Layer 1.2, libraries
ii libsdl-ttf2.0-0:amd64 2.0.11-3 amd64 TrueType Font library for Simple DirectMedia Layer 1.2, libraries
ii libsdl1.2debian:amd64 1.2.15-11 amd64 Simple DirectMedia Layer
rc libsdl1.2debian-alsa 1.2.14-6.1 amd64 Simple DirectMedia Layer (with X11 and ALSA options)
ii libsdl2-2.0-0:amd64 2.0.2+dfsg1-7 amd64 Simple DirectMedia Layer
ii libsdl2-dev 2.0.2+dfsg1-7 amd64 Simple DirectMedia Layer development files
What's wrong?
